53 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> NEED HELP ASAP ON CEILING!
Thu, Apr 26, 2007 at 9:58:32 AM | NEED HELP ASAP ON CEILING!
ellendaniels
I am in the process of working on a corporate office and I have been trying repeatedly to put my ceiling in and it won't work. An error keeps popping up that says "constant height defining lines must be parallel" I have tried all sketch modes to get the ceiling in and it doesn't work. From the elevations it appears that all the heights are the same. PLEASE I NEED HELP ASAP! thank you!
Thu, Apr 26, 2007 at 5:18:15 PM | NEED HELP ASAP ON CEILING!
framerman
4 Stars: 13 Votes
It might sound like you are using the pick tool and maybe selecting something that is sloping or on a lower level?
Try drawing using the line command. When I use this method, I make sure I get nowhere near where I want it, then I use the align command to align to what I need for ceiling boundary lines. Revit seems to have a way of being too constraint driven sometimes.
I don't know how many times I deleted a simple thing and next day many, many items are gone.
Ceiling visbility
Wed, Apr 12, 2006 at 7:21:38 AM
Airport ASAP
Thu, Feb 14, 2008 at 3:35:59 PM
Ceiling objects cut by walls
Fri, Nov 20, 2009 at 12:58:10 AM
Lighting without ceiling
Thu, Sep 10, 2009 at 11:02:51 AM
awkward shaped ceiling
Fri, Mar 6, 2009 at 3:36:14 AM
Page generation time: 2.2091
