38 Users Online (36 Members):
Forums >> Revit Building >> Technical Support >> Sub categories
4 Posts No Rating |
I am trying to create a new sub category but I dont know if I am doing it right. I have a piece of furniture and I want to create a subcategory for it under the furniture family. I first place the object in the floor plan then I click on it and edit family the I go into settings then object styles and then I add a new subcategory. Then I highlight the object and go into the properties and change the subcategory to the one I just created. I then load it into my project. But in the floor plan it does not recognize it as the subategory I placed it under. When I turn off the subcategory in VV it does not disapper. Am I setting up the subcategories wrong? If so how do I create a subcategory?
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
What you described is the correct process... Can you post the family for us to have a look at OR if you don't want to do that post a screenshot of each property you set.
Regards,
Chris.
4 Posts No Rating |
Attached is snapshots of what I have done. I have also attached the family but it happens to all the pieces of furniture including the ones on revit as well as the ones I have downloaded from revit city. Thanks for looking into this!
4 Posts No Rating |
Opps I forgot to attach the snap shots. Here they are.
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
I think there is a more elegant solution to NIC items. I define a shared parameter called NIC that is applied to all categories as a yes/no type. Then if an item is NIC you check the box on. Then I define a filter that checks for NIC = true and over-ride the linework to hidden. This allows you to use any family and use a NIC linework via applying a filter to the view.
Tom www.reviteer.com http://twitter.com/Reviteer |
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
Your refrigerator "family" has symbolic lines drawn in plan view that are not on your new subcategory "N.I.C." These symbolic lines currently reside on the "Specialty Equipment" category. This could be your problem.
4 Posts No Rating |
Tom- I am so sorry but I am very new to revit and I dont understand what you are talking about. Would you please talk about this in step by step of what to do? Thanks so much!
It is a slightly complex procedure, but well worth the effort in my estimation. I did some quick screen shots and created a PDF tutorial for you to follow.
Collapsing Browser Categories & Sub Categories |
Wed, Mar 4, 2009 at 9:29:51 AM
Categories |
Mon, Feb 16, 2009 at 8:48:55 AM
Removing Imported Categories |
Sat, May 20, 2017 at 5:26:29 AM
Un-Taggable Categories |
Tue, Apr 30, 2013 at 11:23:19 AM
Removing categories from Graphic Overrides |
Mon, Jul 14, 2008 at 6:58:05 PM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
