Forums >> Revit Building >> Technical Support >> Save as DWF only?
![DLicata Avatar](user_avatar/31618.jpg)
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
Can you only save a Revit file as a DWF? Or is there a way to save it as a good old PDF? =) I'm using Revit Architecture 2008.
LHAA Licata Hansen Associates Architecture Reno, NV USA |
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
You can print it to a PDF if you have a PDF printer driver installed. Adobe Acrobat Professional works well, but then do many of the freeware PDF drivers. My personal favorite if PDF995 www.pdf995.com Free if you can put up with the pop-up ad, $9.95 if you want to supress them.
Edited on: Wed, Apr 25, 2007 at 3:35:34 PM
Tom www.reviteer.com http://twitter.com/Reviteer |
Ok thanks for the help.
![2.5 Stars: 2 Votes](/images/stars_2.5.gif) |
Primo PDF is a realy good free program.
I'll check it out. Thanks! =)
9 Posts No Rating |
Tom.. thanks a bunch!!! I am an arch student and have a project due tomorrow. It is kind of frustrating that AutoCAD has print to pdf but Revit does not..........
I don't know what you are talking about. We print to PDF all the time in REVIT. You just have to set up yor PDF writing program as one of your printers - just like in CAD.
9 Posts No Rating |
for some reason it doesnt read the pdf writer on my laptop. i can definitely print to pdf at school, but not at home. i had to download an external pdf writer and install it on my laptop.
Like WWHub states, printing to PDF from Revit is a function of having a Windows print driver for PDF's installed. There are tons of free and paid PDF drivers out there, simply pick your favorite. That said, a long time ago Revit actually did have its own PDF writer built-in circa version 4.5 - 6.1. It was pulled out by Autodesk eventually in favor of DWF. While DWF has its merits, hard to compete with the PDF format that is standard everywhere it seems.
![4 Stars: 7 Votes](/images/stars_4.gif) |
Like WWHub states, printing to PDF from Revit is a function of having a Windows print driver for PDF's installed. There are tons of free and paid PDF drivers out there, simply pick your favorite. That said, a long time ago Revit actually did have its own PDF writer built-in circa version 4.5 - 6.1. It was pulled out by Autodesk eventually in favor of DWF. While DWF has its merits, hard to compete with the PDF format that is standard everywhere it seems. " Count me in as one who thinks that pulling the Revit PDF writer was a bad idea. I understand why it was done, but I don't like it. I'd love to use DWF's, I prefer them to PDF. But when all the architects I work with are demanding PDFs, telling them that ADesk would prefer we use DWF just doesn't fly. To the OP, another free PDF writer to check out is doPDF. I've been using it, and it seems to be working ok.
Revit no allowing me to save updates to DWF markup set |
Thu, Oct 23, 2008 at 5:44:11 PM
help! dwf for 2d plans |
Sun, Feb 26, 2006 at 8:15:57 PM
DWF File Size |
Fri, Oct 26, 2007 at 9:52:18 AM
DWF Linking |
Thu, Aug 23, 2007 at 12:55:32 PM
Publishing a .dwf File |
Fri, May 27, 2011 at 1:42:00 AM
Members: | 2022391 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
