56 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> Sweep Profiles and Path's Not Visible
Ive created an in place sweep. The sweep was created in the East view. I've found I need to change the sweep profile. When I try to edit it, the existing profile is not visible, and any new geometry I create gets a "the element created is not visible..." warning. It's not even visible in the 3D view. However, I can edit the path when in the East view only. There is also another sweep I created in the plan view. I can't edit that path in ANY view, not even plan. Nor can I edit the profile on that one in any view. I have made sure that the mass category that I used for the in-place mass is visible in all views. I can also see the created mass in all views - just not the pink-colored path line or editable profile line. The black place holder path line and profile lines ARE visible, however. They go away when I click "sketch 2d path" or "sketch 2d profile." Any ideas?
Sounds like you have "lines" turned off in your visibility settings-->Model tab. They need to be turned on in order to see your sketch. Check this.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
That was it. Thanks!
Sweep Profiles in Version 9 |
Thu, Aug 3, 2006 at 2:14:05 AM
Multi-profile Sweep |
Fri, Jan 22, 2010 at 8:08:14 AM
Sketch a path greyed out...can't alter sweep path |
Mon, Jul 26, 2010 at 4:45:05 PM
Can't make sweep path by picking on 3D edges. |
Fri, Jun 13, 2014 at 4:32:04 PM
3D path insteads of 2D path |
Mon, Mar 28, 2005 at 9:23:38 PM
Members: | 2056243 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
