56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Windows in elevation
Fri, Apr 20, 2007 at 5:49:13 AM | Windows in elevation
Marc9999
Hi,
I have a building elevation which is flat on one part but at a slight angle upon the other.  I have windows with horizontal bars on both parts of the elevation, however when i view the true elevation the part of the building on angle doesn't show the horizontal bars of the windows.  I have checked the visibility settings of the window family which has all views checked for the horizontal bars.
Anyone got any ideas?
Fri, Apr 20, 2007 at 6:45:52 AM | Windows in elevation
Sparky
5 Stars: 3 Votes
post an image pls
Fri, Apr 20, 2007 at 9:36:50 AM | Windows in elevation
Marc9999
Images as attachted
thanks.
Fri, Apr 20, 2007 at 12:10:15 PM | Windows in elevation
Sparky
5 Stars: 3 Votes
If you say you checked the vis setting, im a bit stumped.
Could you post your window fam and ill check it out quickly.
Mon, Apr 23, 2007 at 4:27:53 AM | Windows in elevation
Marc9999
sorry i've been away for the weekend, if you are still willing to look at the family file I attach below.
Cheers
Marc
Mon, Apr 23, 2007 at 5:32:38 AM | Windows in elevation
Sparky
5 Stars: 3 Votes
The reason this is happening is that your glazing bars are within the glass and therefore revit doesnt show it becuase it lies within a solid (it only shows the object closest). In elevation view you have detail lines showing the glazing bars and they only display when perpedicular to a view. (Because they are symbolic lines and not model lines - model lines display in all views because its seen as a model element). Ive attached a revised version of your window. Ive created model lines that only displays in elevations and is is located to the glazing planes - note - this had to be done inside and out. The only problem with this is that these lines will display in 3d aswell - if your scale is so high that you notice them, id suggest creating a seperate object style for the glazing bar lines and then switching them off in your 3d views in the project.
Dunno if anyone else has a better solution though.
DAR
Mon, Apr 23, 2007 at 5:51:11 AM | Windows in elevation
Marc9999
wicked thanks very much for your time.
Tue, Apr 24, 2007 at 10:45:28 AM | Windows in elevation
Marc9999
Spoke to soon, do you know how to ensure the horizontal bars adjust when I adjust the window width?
thanks
Marc
Tue, Apr 24, 2007 at 2:26:46 PM | Windows in elevation
Sparky
5 Stars: 3 Votes
Oops - forgot to do that for ya.
- Edit the family
- Go into your elvation views (front and back)
- Isolate the model lines in question as well as the mullions
- Stretch the lines away from the ends of the mullion
- Use the Allign tool and select the end of the mullion and then the very end of the model line
- Click the Lock symbol that appears
- Repeat and Simmer for 10 minutes Winking
- This is all assuming that your mullions changes with the width of the window.
DAR
Wed, Apr 25, 2007 at 5:05:33 AM | Windows in elevation
Marc9999
perfect, cheers.
Exterior Windows elevation
Sun, Aug 26, 2012 at 5:26:57 AM
12
Revit 2012 Rotate windows in elevation
Mon, Sep 16, 2013 at 3:31:38 AM
mullions in elevation
Wed, Sep 8, 2010 at 9:53:32 AM
help me door and windows pleaseeeeeeeeeeeeeeee
Thu, Jul 26, 2007 at 11:15:14 AM
Excluding doors and windows in count
Wed, Feb 15, 2006 at 2:59:05 AM
Page generation time: 1.1652
