118 Users Online (117 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Override model patterns
Thu, Apr 19, 2007 at 10:55:39 AM | Override model patterns
MYoung
MYoung Avatar
Hello,
 In the visibility/graphics window, I decided to override my coarse model cut pattern to solid black.  It works great for the walls, floor and roof, but it isn't overriding my cut stairs to a solid black fill.
Is there a reason for this/way to get around it?
 Thanks,
Mike
Thu, Apr 19, 2007 at 11:23:10 AM | Override model patterns
MYoung
MYoung Avatar
(version 9.0)^
Thu, Apr 19, 2007 at 6:15:29 PM | Override model patterns
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Interestingly enough i've never come across this...
No for stairs they don't have a coarse scale settings like walls/floors/roofs/ceilings.  The only workaround i can think of its a filled region or creating two stairs in the same place with different materials then hiding the one you don't want to see.  Either way they are not very elegant solutions...
Regards,
Chris.
Fri, Apr 20, 2007 at 10:36:12 AM | Override model patterns
MYoung
MYoung Avatar
Yeah I didn't see any simple solutions either.  Thanks for checking into it though.
 Mike
Where do model patterns go?
Thu, Sep 24, 2015 at 9:37:42 PM
Model Fill Patterns
Tue, Jun 22, 2010 at 11:35:20 PM
Model pattern override
Wed, Nov 10, 2010 at 3:50:55 PM
wall fill patterns for different wall types and phases
Sun, Apr 24, 2016 at 4:42:59 AM
Model Text line weight override...
Wed, Dec 18, 2013 at 9:47:46 AM
Page generation time: 0.6937
