81 Users Online (80 Members):
Forums >> Revit Building >> Technical Support >> dimensions on plot sheet with reference to whats inside a view crop region
5 Posts No Rating |
Revit Verison: 9.1- - 20061202_0700 Gidday, I am currently doing some joinery elevations for a house and I want to know if I can place dimensions outside a crop region on a plot sheet to refer to the height of a benchtop? If I make the crop region bigger then the rest of the elevation shows up and is in the way of the dimension- therefore it is unreadable and also unneccesary information shows up. The only solution I have so far is to perhaps put a "blank" fill region over the unwanted drawing and put the dimension in front of the fill region (if thats even possible)...so basically I just want to know if there is an easy way to put dimensions on a plot sheet which refer to a particular view? Also, is there any way to draw grids on the plot sheet so that they snap to a certain heightline in a view? Any comments much appreciated ![Smile](/images/smiles/smile.gif) Regards, Andrew
5 Posts No Rating |
i HAVE JUST REALISED THAT I CAN DRAG THE DIMENSIONS OUTSIDE THE CROP REGION AND ADJUST THE CROP REGION WITHOUT ANY AFFECT ON THE DIMENSIONS....SO WHAT ABOUT SETTING UP GRIDLINE IN THE PLOTSHEET WHICH REFER TO LEVELS IN THE VIEWPORT?
I'll typically use the first view in the series and extend its levels across so they overlap the ones of the adjacent views, essentially joining it all together. HTH.
Regards,
Chris.
Crop Regions Disappear When I Assign a View Template |
Sun, Apr 22, 2018 at 11:04:20 PM
Viewport extents reaching far beyond crop region |
Mon, Sep 8, 2008 at 5:38:05 AM
crop region changes when placed on sheet |
Fri, Jan 9, 2015 at 3:33:07 PM
Cannot crop drawings in sheet view |
Tue, Mar 17, 2015 at 11:05:51 AM
Revit 2009-Crop Region and Show Crop Buttons Disappeared |
Thu, Jun 25, 2009 at 2:09:47 PM
Members: | 2022512 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
