76 Users Online (75 Members):
Forums >> Revit Building >> Technical Support >> imported autocad 3d block, how to remove line work?
![3 Stars: 1 Votes](/images/stars_3.gif) |
i downloaded an autocad kohler water closet and imported it into the revit family editor. is there a way to get rid of the unwated linework? i am attahcing the family. thanks
![coreed Avatar](user_avatar/14568.jpg)
why not get rid of unwanted linework before importing in Revit HTH
here is the original autocad block.....i don't think you can.
Revit will always show all the triangulations of a imported 3D DWG file. To get around this its best to set the 3D geometry to not display in plan or section and then create masking regions (white filled regions pre 200 so as they conceal elements behind them and to represent the element in these views. HTH.
Regards,
Chris.
i figured that was what i had to do. there is no way to hide the triangulation lines in autocad?
you can't create filled regions in a plumbing category, do you do it in the project?
"i figured that was what i had to do. there is no way to hide the triangulation lines in autocad?" here is your original file with a hidden triangulation version next to it done in Autocad. i don't distinguish between Autocad and Desktop and that sometimes creates problems. i should have said Desktop. sorry for the misunderstanding HTH
Edited on: Wed, Apr 18, 2007 at 2:18:22 PM
Importing AutoCAD Title Block Line Thickness Problem |
Wed, Feb 20, 2013 at 1:40:15 PM
Imported AutoCAD 2006 title block line thickness |
Thu, Sep 7, 2006 at 3:27:44 PM
Revit 2014 Imported Linework |
Wed, May 14, 2014 at 1:16:55 PM
How to import my title block from AutoCAD? |
Mon, Sep 10, 2007 at 4:25:43 PM
12
Uin note block |
Thu, Dec 3, 2015 at 7:06:54 AM
Members: | 2016954 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
