60 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> re-joining (?) cut extrusion with extrusion
Tue, Apr 17, 2007 at 11:29:01 AM | re-joining (?) cut extrusion with extrusion
WYSIWYG
3 Stars: 2 Votes
Hi.  Please teach me how I can "reassociate" (or whatever the correct term would be) a cut extrusion to a extrusion after I mirrored it.  The error I received was "Can't keep elements joined." when I mirrored a table base in a family I'm creating.  In the new epice it still shows the rectangle extrusion with the goasted cut extrusion around it but it is not cutting the extrusion anymore.  Thanks!
Tue, Apr 17, 2007 at 10:26:28 PM | re-joining (?) cut extrusion with extrusion
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use the cut geometry tool.
Pick the void then the element you want it to cut.
Regards,
Chris.
Cut a void from an extrusion
Thu, Feb 19, 2015 at 1:08:45 AM
Joining Roof By Extrusion
Mon, Jan 31, 2011 at 8:15:15 AM
Void Won't Cut Extrusion
Wed, Feb 13, 2013 at 11:04:27 AM
void extrusion not cutting solid extrusion
Fri, Oct 10, 2008 at 3:47:44 PM
Can I cut a hole through an extrusion?
Fri, Apr 13, 2007 at 8:31:52 AM
Page generation time: 2.8026
