48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Visibility Confusion with Pilecap family
Tue, Apr 17, 2007 at 6:36:40 AM | Visibility Confusion with Pilecap family
DaveF
Hi I'm still trying to get my head around visibility settings in Revit.
I posted thisin building but thought I might get a more detailed answer as it concerns things "be;ow ground" :-)
Please see attached file.
I created the 4 pilecap foundation family & I am confused as to why certain elements down show up in certain views:
1. In an elevation with shading on, the pilecap doesn't display. It does in all other settings. Why is that?
2. In Level 1 the pilecap is still visible even though it's well below it. I've tried turning off the pilecap in the visibility dialog & amending the view range, but to no avail. How do I get it to only display the piles as cut?
3. When in elevation I'd like show the pile penetrating into the pilecap. I tried using Hidden cut symbolic line in the front elevation, but these appear in the 3d view. What am I doing wrong?
4. In a plan the piles were set to Hidden Projection. The appears almost continuous at a scale of 1:00, but looks OK at 1:20. Is there a way to get it to look dashed at both scales? I don't understand why it's doesn't scale the linetype like it does for hatching & annotations.
 There's a lot there, I hope you can help with some.
 Thanks
Dave F.
Visibility confusion.
Mon, Apr 16, 2007 at 11:13:25 AM
draw beam between foundations
Thu, Jun 26, 2008 at 3:40:53 AM
Column Confusion
Sat, Mar 21, 2009 at 4:41:06 PM
tags, symbols and annotation confusion
Thu, Jan 17, 2008 at 11:13:31 AM
nested family visibility parameter
Sat, Jan 19, 2013 at 7:34:32 AM
Page generation time: 2.2117
