163 Users Online (162 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> timber frame valleys
Sun, Apr 15, 2007 at 11:03:32 PM | timber frame valleys
pmcg
Does anyone know how to model valley members in a timber frame roof?  I have a timber frame roof system with two intersecting unequal pitch roofs.  I am trying to accurately model the valley members because they will be visible from the finished space below.  Any help would be appreciated.  Thank you.
Mon, Apr 16, 2007 at 9:44:19 AM | timber frame valleys
framerman
4 Stars: 13 Votes
I have responded to a very similar question on AUGI I believe. Give me a few moments and I'll try to find it for you. I'm not sure if there was a complete answer though.
Unequal roof pitches will make it a little more difficult. You will have to make a valley rafter/beam with voids in the top. Then you would have to make some type of angle constraints to adjust for the separate roof pitches.
Mon, Apr 16, 2007 at 10:04:52 PM | timber frame valleys
pmcg
Framerman, if you could locate the link you were referring to, that would be very helpful.  Thanks very much.
Tue, Apr 17, 2007 at 6:25:02 AM | timber frame valleys
jterrell
3 Stars: 5 Votes
Create a 3D view where only the roof and structural members are visible. Rotate the view so you can see the underside of the roof. Now use the "3D Snapping" option in the options bar to draw beams along the valleys and in about 30 seconds (depending on the complexity of the roof) you have your framing.
Tue, Apr 17, 2007 at 9:55:11 PM | timber frame valleys
pmcg
jterrell, thanks for the tip.  That helped a lot.
Wed, Apr 18, 2007 at 3:07:00 PM | timber frame valleys
framerman
4 Stars: 13 Votes
I have to say I'm almost embarassed I didn't know about that. Nice pickup on that jterrell.
I found the thread but it doesn't tell much so there's not really any bother for it.
From my understanding, valleys from timber frames have a notch in the top of the beam. You would still need to create a family or an in place family if you want it to show this way. If it's not a big deal, then jterrell's method works pretty darn good.
timber frame panels
Thu, Jan 12, 2012 at 11:09:38 AM
Timber Framing
Tue, May 9, 2006 at 9:04:40 AM
Timber framing in Revit?
Tue, May 18, 2004 at 11:46:23 AM
How would I go about creating a timber frame?
Fri, Feb 10, 2006 at 3:49:51 PM
Timber Frame Roo
Fri, Feb 20, 2015 at 4:00:54 AM
Page generation time: 0.2644
