Forums >> Revit Building >> Technical Support >> How customise bubbles grid?
Hi to everyone. im trying to customize the bubble`s grid, there are some ways to get that? or any family can be downloaded is avaliable?
i don't understand, the image is Autocad
ok. i want to change the bubble style, how can do that? i want to cutomize it , like autocad's image .
Create a new grid head family or simply edit the existing one and rename it. Then select one of your grids in revit, select its properties-->Edit/New-->Then select your new grid head in the symbol parameter. HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
20 Posts No Rating |
thanks, mr. spot!
GRID BUBBLES |
Fri, Jan 28, 2022 at 10:39:22 AM
Orientation of Grid and Section Bubbles |
Mon, Aug 31, 2009 at 2:57:54 PM
Column grid text too wide to fit in bubble |
Thu, Jul 1, 2010 at 8:32:07 AM
Grid Bubbles relative to scope box. |
Tue, Jul 10, 2007 at 4:20:51 PM
problem with grid bubbles when printing in smaller scale |
Fri, Sep 28, 2007 at 2:02:02 AM
Members: | 2100741 | Objects: | 23171 | Forum Posts: | 152296 | Job Listings: | 3 |
