52 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> creating Ceiling Plans
![5 Stars: 7 Votes](/images/stars_5.gif) |
for some reason my project only created a ceiling plan for my 2nd and 3rd floor, but not for the 1st floor. does anyone know how to creat a ceiling plan if it was not originally created?
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
Go to View>New>Ceiling Plan When you copy a level in an elevation or section view, a new plan or ceiling view is not created. If you place a new level in a view, then on the options bar above the drawing space is a check box that you can toggle on and off to create a plan view and also a button to select view types to create.
![4 Stars: 3 Votes](/images/stars_4.gif) |
http://www.dgcad.com/ You can download some basic training movies for free. (Revit, Acad, ADT...etc.) GL
Thanks for the help. I got it figured out but could not figure out how to delete the post.
![coreed Avatar](user_avatar/14568.jpg)
hi mead3724, it is customary not to try and delete a post, but to post how the problem was solved. even if you solved your own problem. best regards,
How to load back the Reflected Ceiling Plans into the Project Browser? |
Tue, Jun 8, 2004 at 5:41:39 PM
Ceiling Plans |
Mon, Dec 19, 2011 at 10:20:40 AM
Floor Plans need to show Ceiling on them in Revit 2011 |
Thu, Aug 26, 2010 at 12:40:35 PM
To use or not to use . . Floor plan or Ceiling plan . . . for Mech and Lighting |
Tue, Sep 13, 2011 at 11:12:09 AM
Room Tags on Ceiling Plans |
Fri, Mar 4, 2005 at 9:36:28 AM
Members: | 2022314 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
