77 Users Online (75 Members):
Forums >> Revit Structure >> Technical Support >> Structure Suite 2008
8 Posts No Rating |
Ok, So I downloaded the new Autocad Revit Structure Suite 2008. I've install Revit Structure 2008. Where is the install for AutoCAD 2008? When I donwloaded and install Revit 4 Series, AutoCAD 2007 was included and was installed. Am I supposed to download AutoCAD R2008 separately? Thanks.
David |
AutoCAD has never come with Revit on a download. It only comes together on your DVD issue. I understand you can download the trial of AutoCAD 2008 by going to the ACAD 2008 page. I'd imagine you should be able to just enter your serial and it will become the full version. HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
8 Posts No Rating |
Thanks Chris but that's actually not correct. Revit Structure Series 4 Download did include the install for AutoCAD R2007 with the single download. Everyone I've spoken to at AutoDesk agrees that AutoCad R2008 should have come as part of the download for Revit Stucture Suite 2008. But I've gotten the run around for the last SEVERAL hours. My retailer Support team is all out this week at some Autodesk training. Great..... Autodesk Subsciption support hasn't been helpfull either "ahhh!!" Anyway, as a test, I did download and install Autocad R2008 separately but when getting the activation code from Autodesk (via phone) the serial number doesn't work........there is a link between Revit and AutoCAD when you've purchased the "Suite". Anyone else download the Revit Structure Suite 2008 and not have the AutoCAD R2008 as part of that download? anyone????
David |
8 Posts No Rating |
Ok....mystery solved. below is the answer for Autodesk. Dave, Where were you finally able to download AutoCAD 2008 from? If this was done from the trial download, you will be able to run for 30 days as a trial version however you will not be able to activate this with your Revit Series serial number. I have confirmed with the Revit team that AutoCAD is not available as a download for the Revit Series. Only the Revit component is offered for download. You should be receiving DVD media soon which will contain AutoCAD 2008. Hope this helps anyone else out there that may have been confused.
David |
Interesting. I've never downloaded the structural suite of Revit. We have Revit Series and i can assure you that the revit series download for Architecture has never included AutoCAD. Although it would make sense to, i can see why they haven't. The download would be absolutely massive!
Regards,
Chris.
14 Posts No Rating |
I would have to concur with Mr. Spot on this one: our downloads of the RS Series also did not come with AutoCAD 2007. We had to wait for the media to get here for the AutoCAD portion, but had no issues with getting RS4 (series download) up & running. Where did you get that download that included both? I still have the downloads that we use(d) still on our server (both build 20061022_1700 & build 20060810_2300) & neither has ACAD2k7 as part of it.
Jeff |
Autocad Architecture join the Revit Architecture Suite |
Tue, Aug 19, 2008 at 9:14:55 AM
Creating Network Deployments - Service Pack 03 - Revit Architecture Suite 2008 |
Tue, Dec 4, 2007 at 2:39:09 PM
BIM Manager Suite |
Wed, Jul 2, 2014 at 7:38:50 AM
Project Browser - Revit Structure 2008 |
Tue, Jan 22, 2008 at 9:19:03 AM
Tag Suite and Maintain Rooms |
Mon, Oct 28, 2013 at 8:58:38 AM
Members: | 2058013 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
