98 Users Online (97 Members):
Forums >> Revit Building >> Technical Support >> Floor Trench
5 Posts No Rating |
I am needing to create a trench in a floor slab that cuts through the floor and is visible as stainless steel. Any thoughts. Attached is the profile that might give some clarification of my needs.
Depending on how much detail you want to go to.
I would just break the floor where the grate has to go (split the sketch). You could also use an in-place family floor void, if you want to keep it as one sketch.
Then create a hosted profile for your grate, add a floor slab edge to one of the edges and position the profile in the appropriate position. You can then associate the stainless steel material to the slab edge.
![albertiglesia Avatar](user_avatar/119685.jpg)
45 Posts No Rating |
brilliant!!!
"Pleasure in the job puts perfection in the work"
- Aristotle |
Trench Fill |
Sat, Jun 29, 2013 at 4:20:48 AM
My Floor Plan Is Not Showing In Some Views |
Sat, Apr 25, 2009 at 1:54:41 PM
Trench family for underground utillites |
Mon, Nov 10, 2014 at 1:50:19 PM
Ground Floor info. appearing on Second Floor |
Thu, Jun 9, 2016 at 2:24:40 PM
floor sketching |
Tue, Aug 26, 2008 at 3:35:49 PM
Members: | 2022494 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
