36 Users Online (35 Members):
Forums >> Revit Building >> Technical Support >> Stairs - steel & precast conc treads
43 Posts No Rating |
I am trying to tweak the standard residential stairs to show a middle steel stringer and precast concrete tread construction. Two difficulties occur:
1) the stringers stop at the treads, and don't extend up/down to the landings
2) the landings take on the thickness of the treads, which is too thin.
I think I can add a parameter to the stair family to allow definition of the landing depth, but is there an easier way to deal with the stringer (or another family component that would do the trick better)?
See attached file for reference
----------------------------------- -IOeser |
I have heard from good sources that the next version of Revit will have much better stair creation tools.
Personally,
The landings i would ignore and simply create a floor to cleanup this area, you may also need to add a custom built slab edge to demonstrate the stringer trimming with the landing.
There is no way to add parameters to system families like stairs.
Thanks, Mr. Spot! It really helps to know what you -can't- do, as well. I will attack the problem as you suggested, and update this thread if any other work-arounds come about.
Stacked wall core boundary |
Thu, Jul 19, 2012 at 4:46:27 PM
Attaching railings to precast stairs [ 1 2 ] |
Fri, Jan 16, 2015 at 6:37:53 PM
15
Steel grating treads |
Thu, Oct 17, 2019 at 1:25:59 PM
Stairs with Combined Open/Closed Treads |
Sat, Jan 24, 2009 at 9:42:24 AM
Steel Stairs with Channel Stringers |
Wed, Jun 7, 2006 at 11:33:30 AM
Members: | 2022332 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
