42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> String Values in Formulas
Wed, Apr 11, 2007 at 11:48:12 AM | String Values in Formulas
gaadmin
I am familiar with programming but new to Revit.
The short: Regarding formulas, are text parameter (string value) tests allowed in conditional statements?
The long: I have a room schedule and I have created a Calculated Value.  In the Formula field I am using a conditional IF to test the values of other parameters.  I would like to test the string value from one of the text parameters.  A simplified version is this:
IF (Occupancy = "Grade 3", Area/50, Area/40)
With this however I get a message that says: "Improper use of boolean expressions".  If I use:
IF (Area > 600, Area/50, Area/40)
It works.  However the second formula is not the calculation I wish to make, I just used it to test that the issue was with the string expression.
Any help is appreciated!
Wed, Apr 11, 2007 at 2:31:29 PM | String Values in Formulas
TomDorner
4.5 Stars: 25 Votes
You cannot use text in formula evaluations.  If you are evaluting occupancy then you have to take a more sophiscated approach using Schedule Keys to develop a room or area style and then apply that Schedule Key to the room or area.
More in-depth than I can cover in a post.  There are some posts out on www.augi.com that do cover this in some detail.  I think a few that I have even contributed to.
Tom
Tue, Jul 5, 2011 at 11:40:27 AM | String Values in Formulas
revolution9
Further Question on these formulas...
I understand the formula when it relates to an integer and I am able to input the correct formula to create a check between occupancy, load factor, and exits etc.
However, I would like to apply the same type of check into my Room Finish schedule and check between the Wall, Ceiling, Base, and Floor Finishes in the Schedule VS the Room Finish Tag.
So, in short, I have created Shared Parameters called Wall Finish Tag, Ceiling Finish Tag... which are Text Parameters (since we simply enter in the text of each material/finish into the room properties).  I get the Boolean Expression error when I create the formula if(Wall Finish=Wall Finish Tag,1,0). Is this type of formula possible, or can it only work with Integers/Area etc?
Any suggestions on how to make this kind of check work?!
Thank you!!
Tue, Jul 5, 2011 at 11:52:49 AM | String Values in Formulas
3.5 Stars: 401 Votes
As Tom stated many years ago: " You cannot use text in formula evaluations."  Still can't use text in conditional statements.
Tue, Jul 5, 2011 at 11:55:49 AM | String Values in Formulas
revolution9
Fair enough. Is there any way to create the right type of parameter that will allow this check?
What if they were Material/Finish types? I REALLY want this to work!
Tue, Jul 5, 2011 at 12:10:44 PM | String Values in Formulas
Sure, don't use text, use numbers!
That doesn't work for you, does it?  Revit does a lot but it doesn't do everything everybody wants.
You will need to check this manually as you always did in CAD or use the other tools provided by Revit.  Export your schedule to a txt file, open that with excel and put your formula there.  <<< DON'T COME BACK AND SAY YOU WANT IT IN REVIT BECAUSE YOU CAN'T
Tue, Jul 5, 2011 at 12:22:03 PM | String Values in Formulas
revolution9
Hahahaha well it was worth a shot!
I suppose the best way to show this is keep the parameters as text, and keep the 'Tag' parameters in the schedule to compare. I was hoping to provide conditional formatting, but I understand that this is impossible.
thanks for the help. I really appreciate it!
Wed, Dec 4, 2013 at 10:38:12 PM | String Values in Formulas
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Here is a workaround I use.
http://plevit1.blogspot.kr/2013/12/text-string-value-in-formula.html
want more?
You can get more tips at Enjoy Revit
Parameter formulas losing calculated values
Wed, Jun 17, 2015 at 2:23:19 PM
Current date in formula on titleblock
Mon, Oct 8, 2012 at 10:03:30 AM
Understanding Formulas
Tue, Nov 16, 2010 at 1:36:05 PM
14
Creating Dimensions with english and metric dimesnions on one string
Wed, Aug 26, 2009 at 7:15:58 AM
Preloaded Size Values in Revit MEP
Tue, Aug 24, 2010 at 1:54:48 PM
Page generation time: 0.2246
