54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall Poche and Phasing....
Tue, Apr 10, 2007 at 10:42:46 AM | Wall Poche and Phasing....
Thread Post Kudo! #1
taylormeg
This question was asked a long time ago, but no one answered then...maybe I'll have better luck. Winking
I'm trying to get my existing walls to poche and leave my new walls as lines/fill patterns for visual clarity.  Trouble is, I can only seem to do the reverse (new = poche'd, existing = lines), and then only at coarse scale and not medium or fine.
Am I missing something or does Revit just not work like this?
Wed, Apr 11, 2007 at 3:11:52 PM | Wall Poche and Phasing....
aranttila
you can make your poche match your phasing by going into phasing/graphic overrides, then adjusting the materials and materials cut patterns for each phase.  that's how we get our existing walls to show as a gray solid fill and our new walls to just be the face of wall lines.  hope this helps!
-annie
Mon, Apr 23, 2007 at 11:10:22 AM | Wall Poche and Phasing....
taylormeg
worked like a charm.  thanks!
Wed, Jun 20, 2007 at 4:53:35 PM | Wall Poche and Phasing....
inverted
Is there something I'M missing? I'm trying to do the same thing (have new walls poche'd and existing walls as lines) and it's not showing up. I have my view phase set as "new construction" with "show previous + new". I went to settings/phases /graphic overrides/ New /materials / "phase-new" set up as solid fill - black. I don't understand, please help.
Thu, Jun 21, 2007 at 9:22:51 AM | Wall Poche and Phasing....
taylormeg
The "phase" materials only go into effect when the view is not set to that particular phase , ie in a new construction view, exsiting elemants are shown using the "phase-exist" material instead of the cut patterns for the component materials, and the new elements use the componenet materials.
So in order to have poche'd new construction walls in a new construction view, you'll need to set the wall's componenet materials to a solid fill black or grey.
Hope that made sense to you the way it did in my head.....
Fri, Jun 22, 2007 at 11:34:16 AM | Wall Poche and Phasing....
inverted
Hmmm. It just doesn't seem to make sense. So what your saying is that when my view is set to new construction, it's supposed to show the existing walls according to the phase/graphic override material? It doesn't want to do that at either course, medium, or fine scales. I really would like to avoid having to make separate wall types for existing walls and individually setting their "corse scale fill pattern". Please tell me I'm still missing something. Thanks for your help.
Fri, Jun 22, 2007 at 12:19:22 PM | Wall Poche and Phasing....
inverted
Ahhh. I figured it out. I knew there was something I was missing....  I needed to have the phase filter display settings set to "overridden" not "by category". Just a heads up for anyone else having this problem.
Tue, Oct 22, 2013 at 6:14:09 AM | Wall Poche and Phasing....
ArchStudentWIT
3 Stars: 2 Votes
For those who get brought here by google:
http://www.youtube.com/watch?v=yOi2HCMam5s&feature=youtu.be
Wed, May 31, 2017 at 8:40:33 AM | Wall Poche and Phasing....
ares92428
Without having changed any overrides or other settings, you must properly draw objects in the correct phase (new v existing) and then simply change the view's Detail Level setting to Medium or Fine instead of coarse. The poche will fill in immediately.
Phasing & graphic overrides
Sun, Apr 18, 2010 at 12:25:14 AM
Phasing vs materials...Who is the boss when it comes to graphic overrides?
Mon, Nov 12, 2012 at 9:07:55 AM
revit 2016 poche
Wed, Sep 23, 2015 at 2:50:33 PM
Poche Not Printing?
Tue, Sep 10, 2013 at 10:11:37 AM
Wall and Instance phasing warning - Incorrectly Reporting?
Thu, Oct 11, 2018 at 3:37:00 PM
Page generation time: 0.8333
