77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> sheets pre set in template
Mon, Apr 9, 2007 at 6:10:59 PM | sheets pre set in template
daleyy
Does anyone place a full sheet setup inside their template file?  If so, when do you place the titleblocks if you do not know what size the sheet is going to be?
I would like to set them up inside template but it seems like I would have to do a template for each titleblock.
Does anyone have any thoughts on this?
Thanks
DaleW
Mon, Apr 9, 2007 at 7:51:42 PM | sheets pre set in template
coreed
coreed Avatar
4 Stars: 16 Votes
title blocks are designed to sheet sizes, i think you need to know the sheet size to do the title block
you can place as different title blocks within a single template file as you like
i think i might not understand what you are asking, if so maybe someone else can help.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Apr 10, 2007 at 7:58:01 AM | sheets pre set in template
sposton
sposton Avatar
Coreed's suggestion is exactly what we have done. We made a titleblock family for each of our sheet sizes and types, including sketch sheets and presentation sheets. We have all of these in our template file so that they are immediately available when needed.
Stephen
Tue, Apr 10, 2007 at 8:14:52 AM | sheets pre set in template
latemore
latemore Avatar
3 Stars: 2 Votes
in addition to the other suggestions, we go even further.  each sheet has its relevant set of standard notes, as much as we can do.  we also preset our views, with phases and levels and more, ready for placing onto the sheets.  in some cases, those views are even on sheets, with very little in them of course.  we do loads of extensions, so presetting stuff has helped immensly.
Tue, Apr 10, 2007 at 10:47:22 AM | sheets pre set in template
daleyy
Yes, I understand about the titleblocks in the template but I was more interested in what latemore has to say about actually setting up your sheets in the template with notes, views, and other stuff.  But I saw a problem with it if you do not know what size drawing you are going to be using.  So I wanted to know who actually places all of their sheets sets into the template in order and with titleblocks.
 thanks
DaleW
Tue, Apr 10, 2007 at 11:16:32 AM | sheets pre set in template
sposton
sposton Avatar
Ah, I see. We have not gone to that extent, even with our older AutoCAD projects. I can certainly see the benefits, though, especially if a firm has many similar project types or many projects for one client. Our projects vary in size and scope to such an extent that we have not attempted this.
Tue, Apr 10, 2007 at 11:36:32 AM | sheets pre set in template
daleyy
Thank you very much that is what I needed to know.  We do alot of similar types of project but we also have the other size projects as well.  I may test and see what happens.
 thanks for the help
DaleW
Revit 2014 - How to pre-set section settings
Thu, Nov 19, 2015 at 12:36:57 PM
view template applied to each placed view
Thu, Jul 2, 2015 at 2:36:37 PM
Set Revit template so all schedules will be made with a certain fontsize
Wed, Sep 16, 2009 at 4:49:27 PM
Metal Building
Thu, Oct 20, 2016 at 12:30:50 PM
Managing sheets and links
Fri, Feb 6, 2009 at 7:03:06 PM
Page generation time: 1.1714
