90 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> WOOD PLANK FLOOR
Mon, Apr 9, 2007 at 4:41:09 PM | WOOD PLANK FLOOR
DESIGN4BUILDING
DESIGN4BUILDING Avatar
3.5 Stars: 3 Votes
cant see the lines in the plank flooring in render (raytrace) . i can see them in (shades with edges) when accurender
is applied and lines can be altered in direction, but cant see lines in (raytrace). could it be line wight ?? help
Mon, Apr 9, 2007 at 5:10:56 PM | WOOD PLANK FLOOR
puzzle
4 Stars: 10 Votes
Check the material you have on the floor as it may not have any join lines.
Macca
Sunshine Coast
QLD Australia
Mon, Apr 9, 2007 at 5:52:00 PM | WOOD PLANK FLOOR
TomDorner
4.5 Stars: 25 Votes
The lines that you see in the shaded with edges mode are surface pattern lines within Revit controled by the material you have assigned to the object.  These surface pattern lines will not appear when you render the scene.  The Accurender material you assign to the Revit material controls the rendering image.  you need to make sure the Accurender material contains an accurate representation of the material and you may need multiple versions of Accurender materials to control their rotation as they get applied to Revit surfaces.  This is similar to a UVW mapping in  Viz/Max but has to be performed on a material basis in Revit.
Tom
www.reviteer.com   http://twitter.com/Reviteer
help...Wood plank railing gaps
Wed, Aug 17, 2011 at 10:12:06 PM
Wood floor way too shiny.
Tue, Dec 14, 2010 at 7:32:40 AM
Wood Floor ,Pat
Thu, Feb 26, 2015 at 11:44:40 AM
Wood Floor
Fri, Apr 24, 2015 at 6:17:48 PM
wood floor
Sun, Dec 11, 2005 at 9:09:27 AM
Page generation time: 1.8555
