84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Spiral stairs with small diameter
Sat, Apr 7, 2007 at 8:00:53 PM | Spiral stairs with small diameter
unseenwombat
Hi, I'm new.
I'm trying to make a spiral staircase, but I'm working in a small house and need them to be about 5 1/2' diameter. Revit will only let me make a run at a minimum diameter of 7' 2". Any smaller and it says "cannot create run, radius is too small."
How can I make a smaller spiral staircase?
Mon, Apr 9, 2007 at 4:55:33 AM | Spiral stairs with small diameter
Pragati
Pragati Avatar
Hi,
 At the first place, be sure that the extent of your staircase i.e the height which it covers is compatible to the number of risers. If diameter is small and floor to floor height is more, there are chances that revit cannot complete the staircase structure in given small diameter. Please revise this point in your project.
But to be clear, i tried it out here and created a spiral staircase with run diameter of 3' 0" with 18 risers and I did not receive any error dialogue while doing this.
Also, please check the top and bottom offsets in stair properties where we set the 2 extent levels of staircase and check whether if they can take up the number of risers you wish to create.
Attached is the project where i created this staircase that I mentioned above.
 Pragati
Thu, May 6, 2010 at 3:36:44 AM | Spiral stairs with small diameter
kixwaq41
kixwaq41 Avatar
5 Stars: 2 Votes
hey pragati, how do u make those stairs 4 meters tall??
Thu, May 6, 2010 at 6:53:26 AM | Spiral stairs with small diameter
Arafat
Arafat Avatar
3.5 Stars: 4 Votes
hey kix just while creating stairs check out the stair properties ull get ur answer Winking
Residential Spiral Stair
Mon, Feb 16, 2015 at 10:02:06 AM
Spiral Stairs around a Central Post
Sat, Apr 16, 2011 at 9:27:29 AM
Spiral Stairs
Fri, Jul 4, 2008 at 1:34:57 AM
Spiral Stairs
Sun, May 27, 2007 at 8:06:07 AM
Real spiral stairs.
Wed, May 20, 2015 at 2:21:32 AM
Page generation time: 3.5994
