103 Users Online (102 Members):
Forums >> Revit Building >> Technical Support >> AutoCad models????
![4 Stars: 3 Votes](/images/stars_4.gif) |
Hi I was wondering if I could make something in Autocad and then import it to revit. I need to make a special roof construction and I can't do it in revit. Thanks for any answers.
![5 Stars: 2 Votes](/images/stars_5.gif) |
Yes. Revit imports dwg files just fine. To get materials on it: 1. Select Modeling->create mass. 2. Import the dwg file. 3. Finish the mass. 4. Add materials to the faces with the paint tool. Good luck!
Ok i did what you said but i cant see the mass. I've tried twice and couldn't see the masses. I know it created the families mass1 and mass2. Am i doing something wrong ?
Ok i got it. I did my construction in Acad in meters and my revit project is done in milimeters so when i imported file to revit it was so small that i couldnt see it. :p thx that gives so many opportunities...
Exporting Solid Models from Revit to AutoCAD |
Mon, May 23, 2011 at 12:58:48 PM
importing from AutoCAD |
Thu, Jul 19, 2007 at 1:47:15 PM
to who generate 100% revit models and cd's |
Tue, Sep 19, 2006 at 11:54:05 AM
Generic Models |
Wed, Aug 1, 2007 at 12:03:17 PM
Model/Viewport placement Modelspace/Paperspace when exported to AutoCad |
Thu, Nov 12, 2009 at 10:01:09 AM
Members: | 2017040 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
