49 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> Elevation tag visibility
I am currently working on 3 buildings, but they are all in different files. So, to keep all off the sheets in one place, I linked all my models into 1 file. Now, I am trying to make elevations of the buildings. I need different elevations for the different buildings. So, here is what I did. 2 of the buildings are connected and one is by itself. I made a view that has each floor of each building in it, so, you can see all the first floor for instance. Then, I cropped out the views I needed of the buildings. Now, I need elevations of each of the buildings separately, but when I make an elevation of one building, the tag ends up showing in the plan of another building and they end up all over my sheet when I set up the views on paper. Is there anyway of changing the visibility of certain elevations tags so they don't show up when I print? If not, anyone have any tricks for getting them not to show? Hopefully this makes sense. Thanks
Hard to say for sure without seeing a print or screenshot, but you may want to explore 'scope boxes' in Revit. Scope boxes let you assign levels, grids, sections andelevation tags to a scope boxe which is placed in 3Din your Revit model. You can have multiple scope boxes such as Bldg A, Bldg B etc. and assign elements to each scope box. See the Revit help file for a better explanation.
Thanks, but I looked at the related threads at the bottom of the page here and the first one with just hiding the annotation in view worked for me. I may decide to get into scope boxes at a later time though.
There is also a little known property of the elevation called 'hide at scales courser than'. Click on the elevation tag arrow [not the circle] and go to the properties box. If you have elevation tags for example that you don't want to appear on 1/8" plans but do want to appear on 1/4" plans then choose 1/4" as your hiding scale. This lets you hide certain elevations based on logic in your view while still keeping the valid ones for the plan on.
Beam Tag with Top of Steel Elevation ? |
Fri, Aug 1, 2014 at 8:12:42 AM
Creating Interior Elevation |
Thu, Nov 5, 2009 at 4:17:44 PM
Interior Elevation Tag missing from drop down |
Wed, Aug 18, 2010 at 4:28:45 AM
updating/changing elevation tag types |
Wed, Mar 19, 2008 at 9:49:46 AM
Elevation tag |
Thu, Nov 1, 2007 at 3:06:21 PM
Members: | 2017233 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
