69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Project Information - Order of Parameters
Wed, Apr 4, 2007 at 8:32:42 PM | Project Information - Order of Parameters
dmunn
Does anyone know how to set the parameters inside "Project Information" to appear in a set order?
We want to enter our colours here but they need to be in a set order ie. Floor, walls, roof, windows, doors etc. There will be 20 items in total.
I've tried several different ways but can't seem to work out of how it populates the list.
I've tried adding numbers to each parameter, Making them at different times etc. but nothing seems to work.
Any help would be greatly appreciated.
Regards,
Dan
Wed, Jul 9, 2008 at 2:28:01 PM | Project Information - Order of Parameters
jlbrennaman
Does anybody have an answer for this?
Thanks,
Jason
Mon, Dec 22, 2008 at 2:37:11 PM | Project Information - Order of Parameters
callie
Any answers?  The random order of the parameters is driving me crazy.  I know it doesn't affect the work, but I would really like to organize it.
Mon, Dec 22, 2008 at 4:13:39 PM | Project Information - Order of Parameters
I'm not sure what you are trying to do .... but maybe you can do this elsewhere.
For most of us, the project information shows up in our titleblocks and we control what we show there.  Where do you want to display this information?  Why can't these be in normal finish schedules?
Mon, Dec 22, 2008 at 4:15:40 PM | Project Information - Order of Parameters
BTW ... you could have a sheet that controls this information if you have to keep it in the "project information" area .... but I don't see why?  Project information is typically not model information.
Mon, Dec 22, 2008 at 9:27:27 PM | Project Information - Order of Parameters
callie
Sorry for the confusion.  I'm not talking about anything that actually shows up in drawings.  I have added a lot of parameters in the project information, and when you go to settings-->project information, they just aren't in a logical order.  For instance I have parameters of SED1-SED6, and in the project information there is SED1 followed by occupancy, and then something else, and then SED2...It probably sounds silly that I worry about things that don't have anything to do with the actual project or drawings.  I just want our template to be perfect.  Thanks for responding WWHub.
Mon, Dec 28, 2009 at 9:20:08 AM | Project Information - Order of Parameters
grebiwnotnerb
3.5 Stars: 12 Votes
Seriously, an answer here would be nice. I have the same problem and it's driving me mad. I'm on Revit Architecture 2010 and still no apparent fix to this annoyance.
Mon, Dec 28, 2009 at 9:27:25 AM | Project Information - Order of Parameters
Check out this thread at AUGI: http://forums.augi.com/showthread.php?t=38994
Mon, Dec 28, 2009 at 10:14:47 AM | Project Information - Order of Parameters
grebiwnotnerb
3.5 Stars: 12 Votes
Yeah, that works ok if you are just creating your parameters, but say you are me and you have already made like 12 different parameters and each one has a long complicated equation that you don't want to have to retype. This naming thing won't work because the parameter has already been given it's order. I would have to delete it and recreate it using the described method then retype the whole equation. This wouldn't even be that bad if it were just one parameter, but like i said I have like a dozen.
Thu, Feb 3, 2011 at 3:23:13 PM | Project Information - Order of Parameters
NDArchi03
WWHub,
That post also only applies to parameters in families, and won't work for the shared parameters that you add to Project Information.
Thu, Feb 3, 2011 at 3:48:04 PM | Project Information - Order of Parameters
I did not design the program and I have no control over it's modification.  I just try to give some answers that obviously some people don't like.
What some peolple don't understand is that you can rename a parameter ...OLD ... then create the parameters in the right order ... and ctrl-c the old formula and ctrl-vinto the new parameter....
But that is out of the box thinking.
Project parameters are listed in alphabetical order.
Thu, Feb 3, 2011 at 4:02:10 PM | Project Information - Order of Parameters
NDArchi03
WWHub,
I was not trying to attack your advice, and I am sorry if it came across that way.  I did find the link you posted helpful for normal families, and I have found all of your posts I have come across on the site to be informed and very helpful.  I know the limitations of the software are not your fault.  As best as I can figure out Project Parameters do not sort alphabetically, see the attached image, and I am puzzled at how Revit decides to sort things.
Fri, Feb 4, 2011 at 11:33:11 AM | Project Information - Order of Parameters
#13
kchampag
I'm having the same issue. I've added consultants and their contact information to our Project Information. I assumed it would display in alphabetical order. Could it be displayed in the order in which the parameters were created? I did a test parameter to see where it would land, and it is displayed at the bottom.
Any suggestions for this would be greatly appreciated!!
Fri, Feb 4, 2011 at 11:37:44 AM | Project Information - Order of Parameters
#14
NDArchi03
I have been doing some experimenting and I think the order, at least for shared parameters, is based on the order they were created in the shared parameter file.  So to fix my issue, I manually edited my shared parameter file and deleted the parameters I was having issue with, then from Revit I re-created the shared parameters in the order I wanted them listed in my project, then I added them to my project in the same order.  I haven't experimented enough to know for sure if it was the order I created them in the shared parameter file, or the order they were inserted into my project.  The sorting problem I was having earlier leads me to believe the former, but as I said, I can’t say that definitively yet.  I hope this helps.
Fri, Feb 4, 2011 at 11:48:55 AM | Project Information - Order of Parameters
#15
NDArchi03
Just doing some more testing and I stand corrected.  The order that parameters sort in the Project Information dialog is the order they are added to the project.  The order they are created in the shared parameter file has nothing to do with it.
Project Information Parameters
Tue, Jul 27, 2010 at 5:31:46 PM
Scheduling "Project Information" parameters
Mon, Jun 8, 2015 at 12:36:57 PM
New Title Page Label Using Project Information
Sat, Feb 10, 2018 at 11:54:49 AM
Settings - Project Information help
Sun, Apr 17, 2005 at 10:24:55 PM
project information
Thu, Feb 24, 2011 at 1:48:16 PM
Page generation time: 1.8888
