70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> concrete piers
Wed, Apr 4, 2007 at 2:53:05 PM | concrete piers
brl1585
What is the best way to create concrete piers?  I thought about just using a round concrete column...but I need it to be analyzed as a foundation for my foundation schedule.
Thanks
Wed, Apr 4, 2007 at 5:12:54 PM | concrete piers
TomDorner
4.5 Stars: 25 Votes
I would modify the Pile-Steel Pipe family located in the Revit Structure Imperial Library under Structural>Foundations to be a concrete pile.  To use it you would then load into your project and place via the Foundation>Isolated command.  The modified pile will analize as a foundation if you do it properly.
Tom
www.reviteer.com   http://twitter.com/Reviteer
How can I show concrete piles/piers beyond in a section view
Tue, Sep 20, 2005 at 6:59:34 PM
foundation piers
Mon, Feb 18, 2008 at 5:36:12 PM
Brick Piers
Fri, Jul 8, 2011 at 3:14:28 PM
Continuous footings for the Piers
Mon, Sep 30, 2013 at 12:23:17 PM
Incorporating piers into foundation walls
Mon, Feb 18, 2008 at 4:38:45 PM
Page generation time: 2.1309
