31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Family Template files
Wed, Apr 4, 2007 at 1:16:36 PM | Family Template files
derxaj
3.5 Stars: 3 Votes
Is there any way to create a Rolling Eyesft Family Template File where you can predefine parameters inside of the template?  It doesn't appear to be possible to transfer parameters between Families either.  If you have to add more than a few shared parameters to families, it starts to become time consuming.  Does anyone have any ideas?
Wed, Apr 4, 2007 at 1:18:06 PM | Family Template files
derxaj
3.5 Stars: 3 Votes
the rolling eyes face is "* rft"
Thu, Apr 5, 2007 at 8:13:37 AM | Family Template files
Elmo
3.5 Stars: 4 Votes
Yes there is. Simply add whatever parameters you want save it as a normal rfa family and then rename the family to rft family.
Thu, Apr 5, 2007 at 8:57:37 AM | Family Template files
derxaj
3.5 Stars: 3 Votes
Hey thanks!  That seems so obvious, have you ever had problems doing it like this?  Also as a addition to my original question, can someone explain why the "type mark" parameter does not show up until the family is loaded in the project?  Is there a reason Revit did that?   The "type mark" is a type parameter not an instance, so it doesnt make sense to me why it is not under the parameters inside the family file.
Thu, Apr 5, 2007 at 9:01:56 AM | Family Template files
Elmo
3.5 Stars: 4 Votes
Haven't had any problems with doing this. As for your second question I haven't a clue. Smile
Revit 2015 Missing Family Template Files
Thu, Nov 13, 2014 at 6:45:25 PM
Revit 2012 template family files (.rft)
Tue, May 10, 2016 at 7:12:24 AM
uploading template files no help from revitcity admin
Sat, Mar 16, 2013 at 7:49:57 AM
template (.rte) or project (.rvt) files
Mon, Mar 20, 2006 at 3:16:44 PM
template files
Mon, Jan 5, 2004 at 3:05:34 PM
Page generation time: 2.0691
