106 Users Online (105 Members):
Forums >> Revit Building >> Technical Support >> Parameter Formula
8 Posts No Rating |
Does anyone know how to enter a "yes/no" parameter into a formula? This is what my formula looks like right now if(A = yes, (B + C), B) A is a yes/no parameter, but this formula won't work.
![4 Stars: 4 Votes](/images/stars_4.gif) |
if(A,true,false) look up conditional statements in formulas under the help file.
![3.5 Stars: 4 Votes](/images/stars_3.5.gif) |
if(A=1,(B+C),B) When you want to represent a yes no parameter in a formula it is really simple. Yes/On = 1 No/Off = 0.
5 Posts No Rating |
Hi, Can anyone help me with the following- I want my beams above my doors and windows to automaticly change the beam bearing surface. for example: if my window is less than 199cm the bearing surface should be 25cm -> if my window is 150cm the bearing surface shoul be 25cm -> beam should be 25+150+25 beam = 200cm if my window is less than 299cm but more than 199 the bearing surface should be 30cm -> if my window is 250cm the bearing surface shoul be 30cm -> beam should be 30+250+30 beam = 310cm if my window is less than 399cm but more than 299 the bearing surface should be 30cm -> if my window is 350cm the bearing surface shoul be 30cm -> beam should be 40+350+40 beam = 430cm and so on..
If the beam is not in the window family, then it can't be done. If they are in the window family, then set them relative to the top of the window/door. No need for a formula.
5 Posts No Rating |
mmm... still not working.. the beam obove the window has a standard bearing surface of 200 but it should change if the window gets larger.. so I repeat.. when the window is 199cm the bearing surface needs to be 25cm but when its more than 299 it should be 30 cm and so on.. can anyone help me?
5 Posts No Rating |
got it-- if(Width < 2999 mm, 200 mm, if(Width < 3999 mm, 300 mm, if(Width < 4999 mm, 400 mm, 400 mm)))
One family parameter has formula one has none |
Wed, Jun 25, 2014 at 1:05:54 PM
Formula - IF statement |
Wed, Oct 25, 2006 at 6:54:24 AM
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:24 PM
Parameter names with dashes - problem with formula |
Tue, Aug 31, 2010 at 10:28:39 AM
Add 2 to Parameter Formula |
Fri, Nov 9, 2007 at 1:06:13 PM
Members: | 2017035 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
