34 Users Online (33 Members):
Forums >> Revit Building >> Technical Support >> 3d sweep
2 Posts No Rating |
What I want to do is to create a 3d path in a sweep. The only option for the path in a sweep is 2d. I'm doing a staircase with only one cylinder steel support at the center, it's in a "L-shape". So, is Solid Sweep is the only way to draw this tube? or there's other easier way? have anyone done this before? The attached drawings is what I did, but it's not accurate. What I did is I break it up into sections inorder to rotate the curve parts.
You can pick the path for a sweep in 3D. I use a mass or voids in comination to create an edge curving through 3D that can be selected. You may also try using the stair generator and pick a circular profile for a stinger to get what you are after.
Tom www.reviteer.com http://twitter.com/Reviteer |
Can You Flex a Sweep in Components |
Mon, Jun 3, 2013 at 2:09:23 PM
Sweep Profiles in Version 9 |
Thu, Aug 3, 2006 at 2:14:05 AM
How to cut an arch into a sweep |
Thu, May 26, 2022 at 4:02:08 PM
Sweep and Sweep/Blend Component |
Mon, Apr 23, 2012 at 12:36:52 PM
Wall sweep splitting/joining |
Sun, Oct 19, 2008 at 1:29:46 PM
Members: | 2022243 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
