Forums >> Revit Building >> Technical Support >> Can someone give me some tips?
Thu, Dec 16, 2004 at 8:21:41 PM | Can someone give me some tips?
rsf0
Hello. I'm very new to Revit and I'm doing my first door family. I'm trying to make the door in a way it would work well (and diferently) in the three detail levels. I'm thinking a good way is to have coarse for 1:200 scale, the medium for the 1:100 or 1:50 and fine for the 1:20 scale. I guess the details (1:10 , 1:5 and more) would have to be a separate detail family. Do you think this is a good aproach? Can Revit go to 1:20 scale? The door families that came with Revit are very simplified. One problem I'm having is with this door is that the frame is very thin and although in 1:20 or even 1:50 it would work fine in 1:100 (the medium detail) I would like to represent it as a thicker rectangle and in 1:200 I would just see the wall opening and no frame at all. I guess you understand my problem...the wall opening would have to change for each detail level. What would be the best way to do this? I attached an image showing the original dwg detail and some sketches of the detail levels. Thanks!
Thu, Dec 16, 2004 at 11:39:47 PM | RE: Can someone give me some tips?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
It is very easy in Revit to assign different detail levels for various scales. You can also embed detail components for the amount of detail you show in your top image that will only show at a fine level of detail. Personally i find it best to model at a medium level of detail, create symbolic lines for a coarse scale and use nested detail components for fine scales. These can also be linked to the door parameters to change with wall thickness, frame size, etc. Trying to model too detailed, can be detrimental to file size and thus speed. Whilst modelling at a very coarse level you find yourself needing to add detail manually in a lot of views. HTH.
NewBie - Wall dimension tips
Sun, Apr 9, 2006 at 3:27:32 PM
daily tips incoperated in revit
Wed, Aug 18, 2010 at 8:04:36 AM
76 Autodesk Revit Tips And Shortcuts
Fri, Nov 14, 2014 at 12:17:07 PM
Associate Certification Exam Tomorrow, ANY TIPS?
Mon, Oct 24, 2011 at 8:34:38 PM
Is this a Tips and Tricks forum or a side door to the General Discussion forum ?
Tue, Aug 22, 2006 at 11:05:45 AM
Page generation time: 1.5370
