82 Users Online (81 Members):
Forums >> Revit Building >> Technical Support >> Turn truck into ambulance
5 Posts No Rating |
Hi, well i've one question.... i am drawing an hospital and i would lke to turn one of te trucks into an ambulance but i do notknow how to change even the colour of the block, please help thanks
![bauhaus1919 Avatar](user_avatar/16150.jpg)
![3.5 Stars: 9 Votes](/images/stars_3.5.gif) |
Your question generates a lot of other questions about which truck you are basing it on and to what extent you want it modified. What may be easier is if the ambulance in the Downloads area already meets your needs: http://www.revitcity.com/downloads.php?action=search&keywords=ambulance Post again if this won't work, attaching the family you are using and exactly what you want to change about it, and I/someone can help you better.
Edited on: Tue, Apr 3, 2007 at 11:18:50 AM
5 Posts No Rating |
Hello. thanks for the advise it works perfect, but i still would like t know for example how to change the color of a car...thanks!!.
Again, it depends on how the family is made. The Revit default pick-up truck (if that's the one you were using) just has a material parameter where you can pick a new color. Once the family is open for editting, click Family Types and click on the material to change. You could make new types for each color you want to use to put a variety of colored vehicles into the project with one family. Or, just make the material an instance parameter and go full spectrum from a single family and type. I noticed that glass trucks don't look nearly as heavy-duty. Hope this helps.
5 Posts No Rating |
Once again thanks very much its has been helpfull, thanks :-)
Dually Truck |
Thu, Jun 19, 2014 at 11:49:36 AM
revit model of pickup truck box |
Mon, Feb 20, 2017 at 3:56:35 PM
PLEASE HELP! ROTATING AN ELEMENT ON A RAMP (Revit 2014) |
Wed, Jul 9, 2014 at 1:09:47 PM
Tow Truck. |
Tue, May 12, 2009 at 9:55:06 PM
looking for Mining truck Families |
Mon, Mar 28, 2011 at 6:01:05 PM
Members: | 2022512 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
