51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Getting viewports to stack
I am wondering how you can get viewports to line up with each other from sheet to sheet. If you want one floor on one sheet to stack above another floor on another sheet, how do you do that? Or, I have a legend that won't change from sheet to sheet, how do I place it in the exact same spot on all the sheets? Thanks
that one is on the wishlist, you will have use your own make-shift method as far as i know. maybe Revit 2008? HTH
Edited on: Thu, Mar 29, 2007 at 10:09:56 AM
Thanks, thats kind of what I figured.
Quoin stack |
Sun, May 10, 2009 at 4:44:28 PM
Edit Visibility Graphics in multiple viewports? |
Mon, Nov 28, 2011 at 1:37:05 PM
Stack Wall Problem |
Thu, Jun 4, 2009 at 3:17:56 PM
More stack wall problems! |
Sun, Apr 8, 2007 at 3:40:16 PM
Viewports orginizing on sheet |
Mon, Apr 18, 2016 at 10:45:14 AM
Members: | 2017227 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
