Forums >> Revit Building >> Technical Support >> Schedule phasing
I'm doing a renovation and would like to know if it is possible to filter a window/door schedule by the phases. I need to show proposed windows but can't work out how to share the parameters to show in the schedules. Also is it possible to change the Grand Total heading in the totals.
Macca Sunshine Coast QLD Australia |
Yes you can adjust the phasing just like any other view. I might not understand what you want to show but it sounds like you need to add a parameter called "proposed".
----------------------------------- BallewDesigns.com |
I have windows and doors set to different phases, existing, demo, and new construction. I have my schedules set to display different phases, actually three different schedules, one for each phase. Unfortunately, they don't display what I'm trying to acheive. I want my demo schedule to show only demolished windows, but it's listing a lot of additional windows. I get similar results with the other schedules also. Any thoughts?
watch this webcast on Phasing, it should help http://www.placeware.com/cc/autodesklearning/view?id=BSD02-03&pw=Audience HTH
Thanks for that Coreed. Exactly what I was wanting.
Phasing - Building Already Done but Dind't Set up Phasing |
Tue, Dec 15, 2009 at 7:40:42 AM
Schedule concrete volume (including column, slab & beam) by workset |
Thu, Oct 28, 2010 at 8:04:52 AM
Room names Not showing in Schedule [ 1 2 ] |
Tue, Jul 24, 2012 at 7:05:38 AM
20
phasing |
Tue, Oct 23, 2012 at 8:20:21 AM
Phasing moved to Visibilty/Graphic |
Wed, Nov 18, 2009 at 4:11:56 PM
Members: | 2105696 | Objects: | 23178 | Forum Posts: | 152305 | Job Listings: | 3 |
