57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Scale Label properties
Mon, Mar 26, 2007 at 6:07:14 PM | Scale Label properties
daleyy
I placed the scale label into my titleblock and then tested it with multiple scales on the sheet.  The outcome was "as indicated".  How can I change that property?  We either want it to be all capitals and even change the wording.
Thanks
DaleW
Wed, Oct 3, 2007 at 2:41:33 PM | Scale Label properties
techdecary
techdecary Avatar
I also have this problem with my sacle indication in the titleblock. For me I would need to write it in french. Is there as way to change the "as indicated" for wathever i want ??
 thank you
Mon, Aug 11, 2008 at 2:02:30 PM | Scale Label properties
LIZARD2806
3.5 Stars: 7 Votes
I am trying to do this as well, but have not been able to find a way to change the "As Indicated" annotation.  I noted that this thread is over a year old, so perhaps someone has come up with the answer since?  In any event, I did not see anything in these forums (or AUGI), so for those interested, this was my work around:
1.  In the titleblock family editor, make two new instance parameters (I named mine "Multiple Scales" and "Turn off label" ).  I set formula for "Turn off label" to be "=NOT (Multiple Scales) ".  This way when you check multiple scales, it unchecks "Turn off label".
2.  Make a text object with the text you wish to have (in my case, it is "AS NOTED" ).  Place it over the scale label.
3.  Set the visibility of the text object to "Multiple Scales" and the visibilty of the Scale label to "Turn off label".
When imported back into your drawing, you can now toggle between "AS NOTED" and the actual scale (or, the default "As Indicated" ) using the "Multiple Scales" yes/no parameter.
HTH
Edited on: Mon, Aug 11, 2008 at 2:03:43 PM
Edited on: Mon, Aug 11, 2008 at 2:04:04 PM
adding a formula to a label
Wed, Jul 29, 2015 at 8:59:08 AM
Partial Label Annotation
Mon, Apr 20, 2015 at 10:14:21 AM
View Title drawing scale associated to the right and moving with the line
Wed, May 9, 2018 at 5:41:09 PM
Different Scales on Titleblock
Tue, Aug 7, 2012 at 3:56:54 AM
Sheet Scale w/ multiple scale views - cahnge the default?? RAC 2010
Mon, Aug 29, 2011 at 7:58:13 AM
Page generation time: 1.0302
