29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Sweeps
One of my designers has created a sweep for a wall from the base of his wall up to about 5'-0". He is wanting to copy the sweep from one wall type to the other wall types. Is this possible? or is there a way to copy a group of sweeps/reveals from one wall (say export) to other wall types (to insert)? Other than manually adding the one sweep into each wall type individually. This would be a good wish list item. Thanks
Depends on how he created the sweep. Is it built into the wall type? Is it hosted? If it's hosted then it's as easy as just applying it to the wall you want (personally, if the sweep is going to change or may be added to/removed from other walls later, I always use a hosted sweep. Much easier to manage). If it is built into the wall, then it should be as easy as duplicating the wall and changing the material and structure properties of the wall to match the walls you want to add the sweep to (make sense?). Then simply replace the walls you want to add the sweep to with the new wall t ype you created with the sweep built into it. HTH, good luck!
Problem connecting wall sweeps (horizontal and vertical) |
Fri, May 4, 2012 at 2:07:26 PM
Angling Wall Sweeps |
Walls with automatic wall sweeps |
Fri, Aug 31, 2012 at 3:58:55 AM
Can you rotate wall sweeps? |
Wed, May 2, 2012 at 9:23:44 PM
Waqll Sweeps- Revit 2015 |
Mon, Mar 9, 2015 at 10:02:03 AM
Members: | 2019236 | Objects: | 22958 | Forum Posts: | 152182 | Job Listings: | 3 |
