79 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> problem loading components
Sun, Mar 25, 2007 at 8:15:06 AM | problem loading components
schnoodels
hello,
I everytime i try to load a components from the metric library, it loads the last one i already used. i can only use components which are already listed in the template. does anyone know what to do with this problem???
thanks..
Sun, Mar 25, 2007 at 4:18:55 PM | problem loading components
Dgodfrey
4 Stars: 4 Votes
After you load the component(s), reselect components and scan through your choices again. Just by loading the component, it doesn't automatically select it for placement, you have to do that. You would think that it would by default since that's probably why you're loading it but i guess they figured some people load numerous components at a time. I do on occasion.
Mon, Mar 26, 2007 at 6:00:16 AM | problem loading components
schnoodels
thanks
Sat, Apr 25, 2009 at 6:59:27 PM | problem loading components
fixybopixy
i have a problem loading the louver system component, which is attached to this message. when i load it into my project i dont see it on teh drop down componenet list. any idea how i can insert it, either into a curtain wall system or just sitting on top of a curtain wall system?
Sun, Apr 26, 2009 at 6:38:05 AM | problem loading components
4 Stars: 202 Votes
It's a "Window", if you edit that component and go to settings>Family Category and Parameters you can see it's in "Windows" category and in your project, project browser>Families>windows you can see that, just click in windows and select that, place in the wall.....
Sun, Apr 26, 2009 at 2:01:15 PM | problem loading components
fixybopixy
ok i see that its a window, and i was able to place it easily inside a basic generic wall. however, what if i am designing my own curtain wall/curtain grid system that has indvidual panels? usually, u can highlight a panel and then switch it from solid to glazed or vice versa. but it doesnt seem like u can put the louver system into the curtain wall. how can i do that?
Sun, Apr 26, 2009 at 2:21:18 PM | problem loading components
4 Stars: 202 Votes
To "insert" a "Window" in a Curtain wall you must create your window in a "Metric/Imperial Window-Curtail Wall" or in a "Metric/Imperial Curtain Wall Panel", if you want a door you must create that in a "Metric/Imperial Door-Curtain wall", you CAN'T use a normal window or door to place in a curtain wall, Read your HELP file.... or the tutorials: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11091739
Problem loading components
Mon, Sep 28, 2009 at 3:43:40 AM
problems loading detail components
Mon, Jan 29, 2007 at 3:54:18 PM
Loading downloaded components into project
Wed, Aug 1, 2012 at 9:14:43 AM
error when loading components
Wed, Dec 1, 2010 at 2:33:54 PM
Revit 2019. Component, loading/finding/download family.
Fri, Mar 27, 2020 at 8:05:26 AM
Page generation time: 2.1467
