98 Users Online (97 Members):
Forums >> Revit Building >> Technical Support >> Rooms in RCP
![3 Stars: 2 Votes](/images/stars_3.gif) |
We have created our floor plan with room names/#'s and created our reflected ceiling plan. We have inserted room tags into our RCP but some of our room boundaries in the RCP don't even show up so we are unable to insert tags. We've searched through the forum for other problems similar to this and have checked everything. Anyone have any kind of an idea on this? thanks for you help!
![pepsiqueen Avatar](user_avatar/5618.jpg)
136 Posts No Rating |
are you sure you are just placing tags and not making new 'rooms'? (assuming your using revit 9)
I'd rather be riding at whistler. or highland. thats good too.
yes We have tried to place another room in the RCP and it tells us its a duplicate. We have turned on the reference and fill through VG and 90% of our rooms are in color. The rooms which are not won't let us add the room tags. Attached is our RCP
anyone, Bueller Bueller?
![3.5 Stars: 2 Votes](/images/stars_3.5.gif) |
The only thing I could think of would be to check the height of the room in the room's properties. If it is not cut by the cut plane then it will not show.
23 Posts No Rating |
So, this thread was posted 3 years ago, but in the event that someone stumbles upon it with a similar problem, here is the solution I found. For whatever reason, when I placed some of my rooms, they were put in with an 8'-0" Limit Offset. I'm not sure how that came to be, but to fix it, click on the room in plan view and open its Element Properties. Under constraints change the Limit Offset to something above your cut plane for RCP. I changed mine to the ceiling height, which was 9'-0" and then it showed up in RCP and I could tag the room. HTH
2D light family shows too big on RCP legend |
Wed, Jul 3, 2013 at 11:35:44 AM
Sconce in RCP |
Fri, Jun 17, 2011 at 8:16:36 AM
dropping in light fixtures and ceiling fans into RCP's |
Mon, Aug 11, 2008 at 9:19:45 AM
Low elements in a casework family showing up in RCP (Revit Architecture 2012) |
Tue, Feb 5, 2013 at 1:42:21 PM
Unable to view RCP |
Wed, Apr 1, 2009 at 3:55:11 PM
Members: | 2017040 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
