53 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> DATA BASE liked to Revit
5 Posts No Rating |
I m trying to insert information from an exel spread sheet into some fields of a Telephone Device Table. I would like the fields telephone number to read the data from the exel spread sheet. instead of having to insert them manualy through revit. Would that be possible? Is there a way that i could link a field to a txt file or .doc file like it s done for the structural elements in revit where all the date is converved and linked to a .txt standard file. Glenda
Since Revit will not link to an excel spreadsheet here is a work-around. Not nice but it will work. Open an AutoCAD dwg & OLE link in your spreadsheet. Then you can link that into REVIT. You would have to double open and update both trhe autocad & revit files each time the excel sheet changed. NOT very clean & a chance for screw ups. INSTEAD - Why not just highlight your excel file cells - copy them and then paste directly into a revit text box. You may have to add a few cells but this works & is a lot cleaner. You probably could even mess with legends if you wanted to compose it differently.
Setting up ODBC Export with Open Office Base |
Tue, Mar 8, 2011 at 5:32:11 PM
how do you make a family for tel data that will circuit to data board telephone |
Tue, Jan 28, 2014 at 6:39:31 PM
Revit Identity Data export to Navis |
Tue, Aug 30, 2022 at 6:23:11 AM
Room Data Sheet (inc furniture and doors) using a Room Tag |
Fri, Jan 20, 2012 at 9:47:21 AM
Linking bridge measuring data to a Revit Modell |
Wed, Jun 13, 2018 at 11:56:06 AM
Members: | 2042225 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
