Forums >> Revit Building >> Technical Support >> Symbols on Cover Sheet
16 Posts No Rating |
I'd like to show a list of symbols (section marker, elev marker, etc) on my cover sheet, however I can't get them to come in. Is there a way to make a symbol schedule or to drag symbols onto a sheet and not have them linked to anything? I'd appreciate any help you can offer. Thanks in advance!
try this Create a legend view - On the View menu, click New Legend.
- In the Project Browser, expand Legends.
- Right-click Legend 1, and click Rename.
- In the Rename View dialog box, enter Symbol Legend for Name, and click OK.
Add symbols to the legend - On the Drafting tab of the Design Bar, click Symbol.
- Add the following symbols to the legend view, selecting each from the Type Selector and placing it in the legend as shown.
- Section Head - Filled
- Level Head - Upgrade : 1/8"
- wall tag
- door tag
- window tag
Create a text type - On the Design Bar, click Text.
Because the text size for the symbol legend is not available in the Type Selector, you create a text type with the necessary size. You do this by duplicating an existing text type and modifying the type properties. - In the Type Selector, select Text : 1/4" text .
- On the Options bar, click Properties.
- In the Element Properties dialog box, click Edit/New.
- In the Type Properties dialog box, click Duplicate, enter 1/8" text for Name, and click OK.
- Under Text, enter 1/8" for Text Size, and click OK twice.
Add text to the legend - In the Type Selector, verify that Text : 1/8" text is selected, and click to the right of the first symbol to specify the text start point.
- Enter Detail Callout (detail #/sheet #) for the text note
15. Working from the top down, enter the following text for the remaining symbols in the legend: - Level Marker (Level name/Elevation in Feet)
- Wall Tag (Wall Type #)
- Door Tag (Door #)
- Window Tag (Window Type #)
Place the symbol legend on a sheet - In the Project Browser, expand Sheets (all), and double-click Cover Sheet to open it in the drawing area.
- In the Project Browser, click Symbol Legend, drag it to the lower-right corner of the cover sheet, and click to place it.
- On the Design Bar, click Modify to end the command.
HTH
Thank you so much! Do you know if there's a way to show symbols in detail views.
starting symbols legend on cover sheet |
Thu, Jun 30, 2011 at 9:12:03 AM
Cover Sheet Components |
Wed, Aug 31, 2005 at 9:30:03 AM
Cover Sheet |
Wed, Aug 1, 2007 at 11:23:55 AM
Annotation symbols that cover several dependent views |
Thu, Feb 26, 2009 at 4:53:52 AM
Multiple independent sheet index for cover sheet |
Tue, Feb 4, 2014 at 8:28:13 AM
Members: | 2119160 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
