54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> Interactive master Plan Calculations
7 Posts No Rating |
We work on very huge master plans for industrial distribution centers. we are a 100% revit firm.
The problem arises when calculating Square Footages and acerages of open aress, impervious surfaces, right of ways etc for the buildings in a Master plan. I know that most of the Revit users work on excel and then import the file into Revit. but when we have to change orientation of building or add more parking or open space the calcualtions have to be done again. is there a a method in Revit or any other software that can act as an interactive tool with yr masterplan For example after calculating the areas if there are some major changes, can the calculations change with the physical change made to the masterplan and vice versa. I am looking for something that would be more interactive and would make my life easier. any opinions and suggestions r welcome.
Area plans with some custom parameters and key schedules could help you out. Area plans are good at analyzing large chucks of space and then adding up those areas based on properties you assign the areas. Area plans have a built-in bias toward doing BOMA area calculations, but you can simply define your own area types and ignore the built-in BOMA ones. Area plans though cannot account for slopes of sites, so as long as you can live with a flat projection of the surface they might work for you.See the Revit help file for more information on them.
7 Posts No Rating |
I looked into the Revit help file. i did not see anything under site setting. am i not looking in the right place. Also what are BOMA files. Just getting to know Revit better. Thank you so much for yr reply
7 Posts No Rating |
i meant BOMA area calculations
7 Posts No Rating |
i got it...did a google serach. building owners and managers assoc. thank u
Interactive Key Plan |
Thu, Jan 12, 2012 at 8:05:16 AM
Master plan |
Tue, Dec 13, 2005 at 1:03:48 AM
Can the linked revit drawings preserved its phasing setting in master site plan? |
Fri, Apr 4, 2008 at 8:58:29 PM
looking for a keynote master file workaround |
Fri, Apr 3, 2009 at 6:57:06 PM
camera icon interactive |
Thu, Sep 3, 2009 at 1:51:08 PM
Members: | 2017212 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
