44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Family w/ Array Formula
Tue, Mar 20, 2007 at 2:43:51 PM | Family w/ Array Formula
ebtaylor
3 Stars: 2 Votes
I'm trying to create a fence family. I have the post & fence nested into my family and trying to figure out how to create a formula using the array command in my formula. With array you have to give a number for the array. I don't have a number for array since my fence is an unknown length. Anyone one of you guru's out there have an idea or a better solution to this fence family.
all responses greatly appreciated
Tue, Mar 20, 2007 at 3:01:54 PM | Family w/ Array Formula
broncos4life
3.5 Stars: 11 Votes
What you need to do is to have your array as a parameter based on the length.  What I would do is find out how many posts and fence objects you have for a given section like 5 foot or so.  So lets just say that for a 5' section you have 4 posts, you can have your formula equal to something along the lines of "=(length/5)*4  So for this if the fence were 5' it would be qual to 4, 10' = 8 and so on.  I dont really know what exactly your formula would be, but this should give you a start.  If you still cant get it post your family or what ever on here and I will take a look at it.  Just keep in mind that this may give an error if your array formula turns back 1.  If you think this is a possibility let me know and we can work around that as well.
Grant Doherty
Tue, Mar 20, 2007 at 4:05:53 PM | Family w/ Array Formula
ebtaylor
3 Stars: 2 Votes
I have my array based on the length as follows
= Length / Fence
I've tried your solution and get the same results.
I'm able to get my length to flex in Family Types but unable to get my fence/post/plan lines to actually array with the length.
I hope this attaches, see below.
Tue, Mar 20, 2007 at 4:25:20 PM | Family w/ Array Formula
Thread Post Kudo! #4
broncos4life
3.5 Stars: 11 Votes
There you go, take a look at that and see if you can see what I did.  Click on an item in the array whcih will give you the number in the array, and by clicking on that you can add a paramater to it.  Test it and see I tried it with a fence of length 32' and it worked, just make sure that you dont have a fence of lenght eight or you it will fail because you will turn out an array of 1. If you need a fence lenght of 8' somehwere let me know and I will do it differently so it doesnt turn back an error.
Wed, Mar 21, 2007 at 8:45:36 AM | Family w/ Array Formula
ebtaylor
3 Stars: 2 Votes
thanks for your help, I pretty much have it working but now trying to decide or figure the best and easiest way to insert it into model. Would like to be able to either pick a path or be able to select a line and have my fence replace the line. Do either of these seem possible? Or am I wanting to much from Revit?
My main reason for working on this was to get a new line type for a fence then I thought why not make it 3D as well.
I have a family of auditorium seats which was created from a structural template and uses the array. I've been using this as a ref for my family. This family you actually select a point and drag to another point to place the row of seats the exact dist you want, similar to me drawing a fence.
I'd like to post this here if ever get it working correctly. I can see more people needing a fence like this even though its just a chainlink fence.
All help with this would be appreciated
Wed, Mar 21, 2007 at 11:37:56 AM | Family w/ Array Formula
ebtaylor
3 Stars: 2 Votes
broncos4life or others,
can you tell me what you did to my model other then add the parameters. I'm trying to create the same family in a diff. template to make it easier to insert into model but can't re-create what you did.
When I select the posts or fence I get a temporary dim which reads ' Fence Post 3 ' etc. I'm unable to re-create this in new family. Your help is greatly appreciated or anyone else.
thanks
Wed, Mar 21, 2007 at 2:01:50 PM | Family w/ Array Formula
broncos4life
3.5 Stars: 11 Votes
What you need to do is create a two pick family so then you can just pick the points that your fence will go to and it will draw it for you off of thoes points.  The issue with this is that I dont know how to create a two pick.  I will check and see about how to create a two pick and get back to you, but yes it is possible to do this in revit you arnt wanting too much from revit.  Secondly to add the parameters you need to make your arrary for each of the components and then click on one of the components.  Doing this will show you a number of how many components you have in the array.  Click on this and the go to the parameter setting and click the down arrow and say "Add Parameter".  Then just call it what ever you want.  Then in famly types you need to add in the formula in the 3rd colum (1st being name of parameter, 2nd being the number, 3rd being a spot to put formulas.)  So when you say that you click on a fecne post you get a temp dim of 3, click on that to select the dim and then at the top right above your work area you have a parameter selection, click the drop down and chose to add parameter and just call it what you want.  I will get back to you on the two pick.  If you need help getting to the adding the parameter let me know and I will walk through it and post it using print screen.
 Grant Doherty
Fri, Mar 23, 2007 at 9:26:25 AM | Family w/ Array Formula
Elmo
3.5 Stars: 4 Votes
I did a few fence families a long time ago not sure if these are what you wanted to achieve. Have a look.
Fri, Mar 23, 2007 at 9:29:37 AM | Family w/ Array Formula
Elmo
3.5 Stars: 4 Votes
Here is a line based family that should give you a better example on how to do them.
Beam Family Array Formula Help
Thu, Oct 23, 2014 at 9:40:34 AM
Variable Length Family with Array Formula
Wed, Aug 8, 2012 at 9:56:46 AM
Array Formula
Tue, Dec 9, 2008 at 11:11:51 AM
Array formula (9.1)
Mon, Sep 24, 2007 at 7:12:47 PM
Family Array
Thu, Dec 31, 2009 at 3:46:22 PM
Page generation time: 2.2813
