52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> mullion spacing
Fri, Mar 16, 2007 at 6:05:48 PM | mullion spacing
webb
webb Avatar
I'm trying to create a curtain wall family (or adjust a current one) to have multiple lengths of the spacings on the curtain grid.  the ultimate spacing would be a, b, c, b, a for a wall segment that is a repeated in my project.  so far I've investigated creating a formula in the vertical spacing field within the type properties, but I can't figure out what the syntax would be to create a series or a sequence of values.  does any one know how to write this?  is there a better way to do it?
thanks.
Cutian Wall Horizintal Mullion Spacing
Wed, Jan 19, 2011 at 10:51:31 AM
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing
Mon, Jan 19, 2015 at 7:41:36 AM
storefront mullion moving
Fri, Jun 13, 2008 at 11:00:27 AM
mullion ang transom not fitting well [ 1 2 ]
Wed, Oct 9, 2013 at 11:42:10 PM
23
Curtain Mullion eats into vert mullion
Thu, Jan 22, 2015 at 4:49:08 PM
Page generation time: 0.2595
