68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Text TYPE PARAMETERS
Fri, Mar 16, 2007 at 11:02:48 AM | Text TYPE PARAMETERS
DTCesarz
DTCesarz Avatar
5 Stars: 4 Votes
I'm setting up a titleblock and am having some issues with parameters. I want to add/edit an existing text parameter (drawn by) so that it remains the same on every page, and I don't have to continually add in this information.  I figured I could do it manually throught a txt file but I cannot find the origional parameter to copy. Can anyone help?
Fri, Mar 16, 2007 at 11:11:18 AM | Text TYPE PARAMETERS
Edit your title block & change it per project is the easy fix.
Fri, Mar 16, 2007 at 11:36:12 AM | Text TYPE PARAMETERS
DTCesarz
DTCesarz Avatar
5 Stars: 4 Votes
I'm talking about a within project change. EX: the "drawn by" parameter I would have to put a name in for each sheet I create. The firm would rather have it so that that parameter is only entered in once, and appears on every page... similar to the way the project number and date stay on every page. I think I need to do this manually throught the .TXT file that is created when making a parameter.
Fri, Mar 16, 2007 at 3:56:36 PM | Text TYPE PARAMETERS
As I said - modify your sheet.... take out the drawn by parameter and add the name you want to be on every sheet.
Mon, Mar 19, 2007 at 8:46:40 AM | Text TYPE PARAMETERS
DTCesarz
DTCesarz Avatar
5 Stars: 4 Votes
Maybe I'm not understanding you, sorry... You are saying to add in the drawn by parameter, then go to the properties menu and enter in the drawn by information once loaded- right? However, as I add multiple pages with that titleblock I loaded I continually have to go back to the properties (in the loaded block) and add in who has drawn the sheet (not the parameter "drawn by". As anal as it sounds, I would like it to be entered in once (sim. to the project # and date) and not have to add specifically who has drawn each individually sheet.
Type label question
Fri, Jan 14, 2011 at 11:16:08 AM
RAC 2013 - Transfering wall parameters between projects
Tue, Jun 25, 2013 at 11:58:23 AM
text box leader alignment
Sun, May 9, 2010 at 7:48:44 AM
Shared Parameters
Thu, Feb 9, 2006 at 1:41:58 PM
Category>Family>Type question re: text
Wed, Jul 29, 2015 at 7:03:18 AM
Page generation time: 3.7206
