75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Coarse Fill Pattern for Footings and Foundation Walls
Fri, Mar 16, 2007 at 10:17:18 AM | Coarse Fill Pattern for Footings and Foundation Walls
LIZARD2806
3.5 Stars: 7 Votes
First,  Thanks to everyone for the questions and answers.  I am a new user and trying to guide the rest of the office in the switch(jumping in to the deep end, no less) but Revitcity has been a huge help.
Anyway, I am trying to get my sections to read properly.  I would like all the walls poched (solid fill) at the coarse level.  I have done this easily with all my walls except foundation and footing.  I know I can make the cut pattern of the concrete matrerial solid fill, but I want the concrete hatch in medium and fine views.  This is the first time I am really banging my head against a wall.
 Thanks in advance.
**Using Revit Architecture 2009, 2011, and 2012**
Fri, Mar 16, 2007 at 1:01:48 PM | Coarse Fill Pattern for Footings and Foundation Walls
archdan
3.5 Stars: 2 Votes
To do this you need to set the coarse scale fill pattern [Select wall>Properties>Edit/New> Coarse Scale Fill Pattern] to Solid and then edit the structure for the wall and select the concrete layer in your wall type and click the select material box at the end of that entry box.  THis should bring you into the Materials window with your material selected, here you should change the cut pattern to Concrete fill [or whatever fill you want shown].
This should work how you want it to in coarse scale as well as Med/fine scales as well.
Fri, Mar 16, 2007 at 1:15:57 PM | Coarse Fill Pattern for Footings and Foundation Walls
LIZARD2806
3.5 Stars: 7 Votes
Thanks for the reply.  The problem is that Revit's foundation and footing do not have that option in their properties->edit/new location.  There is no graphics tab there at all.  These are items added from the structural menu.  My only solution may be to make my own walls, but it would seem silly that I would have to do that.
Wed, May 30, 2007 at 2:53:08 PM | Coarse Fill Pattern for Footings and Foundation Walls
pepsiqueen
pepsiqueen Avatar
did you happen to solve this problem? i just ran into it... i have footings and roofs created as sweeps that i cant specify coarse scale fills for. i am running revit 9.1
I'd rather be riding at whistler. or highland. thats good too.
Wed, May 30, 2007 at 3:38:16 PM | Coarse Fill Pattern for Footings and Foundation Walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In 2008 you can override hatches per view...
Regards,
Chris.
Existing Walls with Coarse Fill Pattern Revit 2008
Wed, Aug 13, 2008 at 3:28:01 PM
Tue, Apr 29, 2008 at 8:48:54 PM
dashed line for foundation footings?
Thu, Feb 9, 2006 at 4:04:06 PM
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
Revit 2013 text in coarse scale fill patterns
Mon, Feb 11, 2013 at 7:27:59 AM
Page generation time: 2.2165
