56 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> BE AWARE .... REVIT problems with mirroring
Thu, Mar 15, 2007 at 2:48:43 PM | BE AWARE .... REVIT problems with mirroring
BE AWARE ... REVIT seems to have problems with mirroring certain types of families.  Detail families are usually turned upside down.  It takes another mirror to get them right side up.  I've also had problems with other families.   Most of the time it's an easy fix but it's just annoying.
Thu, Mar 15, 2007 at 8:03:03 PM | BE AWARE .... REVIT problems with mirroring
psymon
psymon Avatar
3.5 Stars: 6 Votes
We have trouble with 2 pick families. Especially when they are grouped.
We have a 2 pick cupboard, when it is in a group, and that group is mirrored, the cupboard does not mirror. You have to edit the group and fix it.
Tue, May 22, 2007 at 12:43:55 PM | BE AWARE .... REVIT problems with mirroring
samov
had the same problem a while back...
i found that using a group that contained another group and some objects did this a lot.
the partial solution was to use only groups to make up the bigger one. and not a combination of objects and groups
Edited on: Tue, May 22, 2007 at 12:52:12 PM
Edited on: Tue, May 22, 2007 at 12:52:44 PM
mirroring problems
Tue, Sep 14, 2004 at 12:04:28 PM
Mirroring
Mon, Oct 14, 2013 at 4:28:30 PM
More Mirroring
Fri, Mar 23, 2007 at 1:01:52 PM
Mirroring House model
Wed, Oct 27, 2004 at 4:33:15 PM
Mirroring problems
Fri, Mar 23, 2007 at 5:06:31 PM
Page generation time: 1.6571
