60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> focuces on object
Thu, Mar 15, 2007 at 9:43:32 AM | focuces on object
thanenbauk
i just imported a dwg object i see it on the 3d view
but can't see it on the plan neither on elevation
is there a command to zéro in on the object ?
like the F key in Maya to move the view to the object for the plan and elevation
thx
perfect
Thu, Mar 15, 2007 at 3:12:42 PM | focuces on object
Type VP in either your plan view or elevation, scroll down and turn on your crop region & make crop region visible.  This will show you the "Extends of your current window.  Grab the handle and pull it out until you can see what you need to see.
Sun, Mar 18, 2007 at 4:41:39 AM | focuces on object
thanenbauk
thx that work but its strange that doesn't exist a center view to object even autocad got this i though
but thx its ok Smile
perfect
Embedded Detail Component and Object Styles
Fri, Feb 12, 2010 at 3:21:26 PM
Object parameters
Mon, Jul 28, 2008 at 12:53:07 PM
Object Style not showing unless object highlighted
Thu, Jun 8, 2017 at 3:29:25 AM
keynoting hidden object
Tue, Jul 6, 2010 at 1:48:10 PM
solid object from 3D dwg
Thu, Apr 16, 2009 at 5:17:18 AM
Page generation time: 3.1700
