Forums >> Revit Building >> Technical Support >> Can I convert detail lines to model lines
Half way through I realised it would be handy to have the lines in tjhe model. DOH! Can I swith them or is it a redraw? Thanks
far as i know you cannot switch detail lines to model lines HTH
Thanks Thought not
4 Posts No Rating |
YES YOU CAN: not in Revit but here's the workaround Create a view with just the Detail Lines you want to convert to Model Lines. Export them to AutoCAD then import them back in (not linked, Origin to Origin) and Explode, they come in as Model lines. You can then adjust the style etc. To separate them out in a view put them on a new Workset and set the Visibility to see only them. Make sure you set your export table settings to an appropriate level in AutoCAD because when you bring it back in it will create a line style called that layer. Mop up the created Workset & imported line style (because we all know Revit files tend to get cluttered) and all is good.
1 Posts No Rating |
An easier way to Convert Detail Lines to Model Lines: Select all your lines and Edit > Cut (to the clipboard) - Initiate any tool that goes into sketch mode (eg the Floor Tool) - Edit > Paste Aligned > Current View your copied selection in the sketch window - The pasted elements will now be model lines - Select all your lines and copy them (again) to the clipboard - Quit sketch mode - Paste Aligned > Current View (again) your Selection in the modelling window - your detail lines are now model lines. Cheers
Edited on: Fri, Dec 7, 2007 at 1:47:16 PM
Thanks Think ouside the software.
12 Posts No Rating |
This also works the other way round - to convert model lines to detail lines, just use Filled Region sketch mode instead of Floor etc.
Can you convert model lines to detail lines? |
Wed, Mar 31, 2010 at 12:45:23 PM
MODEL LINES VS DETAIL LINES |
Mon, Jul 10, 2006 at 9:11:05 PM
Model Lines to Detail Lines??? |
Sun, Aug 31, 2008 at 9:24:50 PM
Symbolic Lines and Model Lines |
Wed, Mar 22, 2006 at 12:52:17 PM
Convert Lines |
Tue, Jan 25, 2011 at 5:03:38 PM
Members: | 2122675 | Objects: | 23210 | Forum Posts: | 152313 | Job Listings: | 3 |
