119 Users Online (118 Members):
Forums >> Revit Structure >> Technical Support >> Columns on plan
15 Posts No Rating |
What in particular governs the look of a column on plan within that family. For instance, I have a column that is 300x800 at the main floor but changes it's profile and should look 300x1050 at L2, but it is only 300x800.
22 Posts No Rating |
Did you happen to develop a column the size you wanted? What you possibly need to do is create a column the size you want and remember to rename it to that size.
It's the same column, it's 300x800 at it's base, and 300x1050 at the top.
If I understand this right, what you are looking for is a tapered column? That you wil have to develop a new family of columns.
This might be off the mark but you can always add symbolic lines to the family that will always display in plan the same, regardless of the cut plane. I do this with detailed elements usually but you can do it with anything.
----------------------------------- BallewDesigns.com |
3 Posts No Rating |
Could you possibly explain a little more what you mean by adding the symbolic lines that always display in plan the same way? I'm also pretty new to Revit, I can't seem to find much in the way of explanations re: the use of symbolic lines... Thanks!
You can make the visability of the 3D object not-visablie in plan view. If you add symbolic lines in the plan view that are defined by the portion of the column you want to see that is what will allways show up in plan regardless of where it is cut in elevation. Do not use Model lines. Model lines show up in every view. Symbolic lines show up only in the view drawn. Think of it like a detail line. Also very usefull for things like details in section.
Showing columns from the floor above |
Mon, Jun 9, 2008 at 1:49:48 PM
hidden columns |
Fri, Mar 26, 2010 at 10:53:36 AM
Leaning columns |
Sat, Jul 2, 2011 at 7:56:56 AM
Plan Region Problem with Columns |
Tue, Mar 25, 2008 at 4:04:09 PM
Cut Pattern - Timber Columns in plan views to black ? |
Tue, Mar 18, 2014 at 7:41:46 PM
Members: | 2030612 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
