Forums >> Revit Building >> Technical Support >> HOW DO I ADD NEW FASCIA?
4 Posts No Rating |
Hi guys Just quick question, I'm trying to add a roof fascia consisting of 2x8's, when i try to go to host sweep-fascia the only options they have for me to pic from are 2 by's and i cant find how to make my own. Does anyone know how i can add or make my own fascia profiles?
4 Posts No Rating |
Never mind, answered my own question, it is very simple thank you REVIT! I just opened new family, with hosted-profile template and created my new fascia loaded it into project, and wala it was there.
Any profile can be used as a Fascia. I don't know what comes with Revit but you can create a profile family very easily with the hosted profile family template. Just draw a closed loop of any shape and save it.. If you want to get fancy you can add controls and design multiple family types like 2x4,2x6,4x12 whatever...I added a sample
----------------------------------- BallewDesigns.com |
4 Posts No Rating |
thanks robin that was very kind of you!
I've created a new fascia profile but cant get it to load under roof fascia. It loads under profiles, how do I get into the correct category so its an option under fascia? In my family file under family category & parameters under profile usage I have it set to fascia. thanks
figured it out, just needed to go a lit' bit farther with properties to edit then change to the profile I wanted.
Fascia on Sloped Glazing |
Tue, Aug 23, 2005 at 11:58:53 AM
Fascia Board Too Long |
Tue, Nov 20, 2012 at 10:19:31 AM
Transparetn fascia |
Thu, Oct 16, 2014 at 11:00:01 AM
How to miter a fascia on a sloped roof? |
Fri, Aug 24, 2012 at 7:48:23 AM
Sloped Fascia |
Thu, Apr 24, 2008 at 8:25:05 PM
Members: | 2101578 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
