48 Users Online (47 Members):
Forums >> Revit Systems >> Technical Support >> Grid symbols
5 Posts No Rating |
how can i edit the grid head circle? it a little bigger then i need i need them a bit smaller. I can't edit by edit profile, does not give me that opition. Also, the horizontal grids don't show on the floor plan but it shows on the elevations. why is this. Any help can be appreciated.
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
For the grid circles you need to modify a grid annotation, load that annotation into your project and assign the annotation to a grid style. The Grid annotationas are located in the annotations section of the imperial library that ships with Revit. Modify and save one of these with a smaller circle to a new standard location for your office. Load the new annotation into a project, hopefully your template file and then select an existing grid line. Go to the properties of the grid line and edit the type properties to use yur newly loaded grid annotation. For grids that don't show up in elevation, make sure that they fully intersect all the levels and get intersected by your elevation. Also be aware that Revit will not display grids that are not orthagonal to your view. i.e. at 90 degrees to yur elevation.
Tom www.reviteer.com http://twitter.com/Reviteer |
Deleting import symbols |
Thu, May 8, 2008 at 3:14:21 PM
symbols, detail components |
Mon, Jan 23, 2012 at 6:35:40 AM
SYMBOLS |
Fri, Mar 6, 2009 at 11:02:48 AM
Electrical symbols - scaling |
Tue, Feb 5, 2013 at 7:18:56 AM
Text Symbols? [ 1 2 ] |
Tue, Apr 28, 2009 at 2:43:34 PM
22
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
