128 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Swaping out parts in a family
Thu, Mar 8, 2007 at 10:13:42 AM | Swaping out parts in a family
WYSIWYG
3 Stars: 2 Votes
Hi.  I'm modeiling a sneeze guard family and I was wondering if anyone knew if there was a way to swap out parts?  For instance, when the guard is brought in to a project could the user choose if they want to use the sq profile or the round on a prebuilt peice? Swap it out later if they changed their mind?  NWIM?  Also these guards need to have a support every 48" so ideally it would be great if I could set it up so that the user picks the beginning of the run and the end of the run and then Revit would add the support every 48".  Impossible?  otherwise I'll just build it so that it's in 48" segments.
Thanks!
Thu, Mar 8, 2007 at 11:15:24 AM | Swaping out parts in a family
ArchWestCY
4.5 Stars: 7 Votes
For your supports you will want to set up an array.  Once you get the first one in place, array the other end as a "Move to last".  Then set the number of the array to a parameter.  In the family type dialog, set up a formula for the array as = Width/4' + 1.  You may need to work on the formula a bit until it behaves the way you want it to.  As for the profile of your frame.  Try setting it up as a sweep.  In the sweep set the profile to have a parameter that the user can set later.  This should solve both of your problems.  Let me know how it works.
Family editing is not easy, and requires a lot of patients.  Good luck.
ArchWestCY
Thu, Mar 8, 2007 at 11:31:32 AM | Swaping out parts in a family
robinballew
robinballew Avatar
3 Stars: 4 Votes
 I have had little luck setting up multiple sweep parameters that are adjustable without editing the family. I would make the 2 or 3 options as separate families and import them into the Sneeze family. In the Sneeze family I would add a "family" parameter that references the loaded families. I have used this a lot for cabinets with various door styles and interior doors with various panels. Let me know if you need more help... Don't want to go to far if it is obvious what I am describing.
BallewDesigns.com
Thu, Mar 8, 2007 at 12:28:30 PM | Swaping out parts in a family
WYSIWYG
3 Stars: 2 Votes
Thank you both.  I will try your suggestions.  I have another question for you - is there any way to blend or join extrustions?  I am creating these rails and I have one that is vertical, one thea is horizontal and one that is at a 45 and I'd like to join them all with a welded joint.  The extrusion also has a recess in the extrusion where the galss will go.  See attached.  i'm breaking a sweat here - tough but fun.
Thanks.
Thu, Mar 8, 2007 at 12:45:07 PM | Swaping out parts in a family
robinballew
robinballew Avatar
3 Stars: 4 Votes
Use the Sweep command.... See attached
BallewDesigns.com
Thu, Mar 8, 2007 at 12:54:39 PM | Swaping out parts in a family
WYSIWYG
3 Stars: 2 Votes
Thank you Robin a thousand thank yous!  Whooo Hoooo Smile
Tue, Dec 4, 2007 at 3:44:57 PM | Swaping out parts in a family
roojesj
How did that sneeze guard turn out? Just started one and saw this post. Any hints to help make it parametric?
Parts
Fri, Sep 16, 2011 at 2:25:11 PM
Materials list for individual parts in a family
Tue, Jul 19, 2011 at 10:04:56 AM
Parts / Structural Deck Visibility
Mon, Jun 15, 2015 at 5:00:31 AM
Parts v cut profile
Wed, Feb 8, 2017 at 11:01:09 AM
revit family that adds parts as you adjust it
Tue, May 3, 2016 at 6:32:23 AM
Page generation time: 1.1255
